cutiegirlracing Posted December 9, 2005 Report Share Posted December 9, 2005 Some interesting stuff about how a 2 stroke exhaust helps to make power. The exhaust pipes on a 2 stroke works by redirecting sound waves to help pull exhaust gases from the engine's exhaust port. After your engine fires it releases the gases out of the port, along with this comes the soundwaves. The sound travels down the head pipe where it comes to the megaphone which redirects some of this sound back to the engine. The reason this a cone shape is because it changes the sound to a longer, but less powerful wave. The longer wave makes it more likely to arrive when the exhaust port is open, to soon and it does no good. The sound arrives ,if time right, by the length of the head pipe, when the port is open and travels back down the head pipe pulling with it the exhaust gases. But wait there's more. After all this is done the noise comes out of the megaphone down the belly, straight section of the expansion chamber, and hits yet another megaphone. This reversed megaphone redirects, yet again, the sound waves back towards the exhaust port. The sounds waves arrives and teams up to make more useful negative pressure. The timing of this wave is time by the length of the belly of the explansion chamber. If timed right not only will the soundwave create a negative pressure to help remove exhaust gasses from the engine it will push the freshly charge gasses, that came out with the exhaust gasses, back into the engine right before the piston closes the port. The silencers help this process by creating pressure making the air more dense sound travels better in a more dense atmoshere. Sound coming out of your engine at 1000rpm is 16.6 hz, while sound coming out at 9000rpm is at 150hz. So the sound out of a higher rpm is a shorter wave length than the lower rpm's. So pipes that are tuned for higher rpm, or higher wavelengths will have shorter head pipes and expansion chamber bellies, or in theory they will. A modern pipe should have an almost straight length, to help get the gases away from the port fast, then a slight cone to start the soundwave process back, then a 3rd cone with a strong taper to redirect the wave back, a belly to time the returning wave from the reversed cone, this will also be a mutiangle cone, then a straight pipe to the silencers. Quote Link to comment Share on other sites More sharing options...
Shee_Rookie Posted December 9, 2005 Report Share Posted December 9, 2005 hmmmmm, With all this "technical knowledge" you are providing. I'll ask again for all us guys, how about a picture of your new rack. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted December 9, 2005 Report Share Posted December 9, 2005 How does wider and higher exhaust ports affect this? Quote Link to comment Share on other sites More sharing options...
Brooke Posted December 9, 2005 Report Share Posted December 9, 2005 hmmmmm, With all this "technical knowledge" you are providing. I'll ask again for all us guys, how about a picture of your new rack. 446800[/snapback] dont hold your breath, shes a dude http://www.bansheehq.com/forums/index.php?showtopic=53799 Quote Link to comment Share on other sites More sharing options...
Shee_Rookie Posted December 9, 2005 Report Share Posted December 9, 2005 Why the fuck would someone want to pose as a chick and try and act all hot?? Some people are just strange. Well Brooke, since I don't want to see he/she boobies anymore. How about another nice shot of your lovely ass?? please ..... Quote Link to comment Share on other sites More sharing options...
350TwinDeathBed Posted December 9, 2005 Report Share Posted December 9, 2005 Why the fuck would someone want to pose as a chick and try and act all hot?? Some people are just strange. Well Brooke, since I don't want to see he/she boobies anymore. How about another nice shot of your lovely ass?? please ..... 446864[/snapback] Haha, I agree. I liked that avatar! I also agree on this bs with "cutiegirl", you've gotta be pretty messed up to try to pose as a girl and get a group of guys drooling over you. Does that help your self esteem "wannabeagirlie"? Then he goes and pretends like he doesn't know anything about his Banshee that his dead bf gave him, yet rambles on about how 2 stroke exhausts and boost bottles work. Lame dude, really lame. Delete your name and go back to your jetski forum, unless of course you actually own a Banshee and want to make a legit name. Quote Link to comment Share on other sites More sharing options...
cutiegirlracing Posted December 11, 2005 Author Report Share Posted December 11, 2005 How does wider and higher exhaust ports affect this? 446806[/snapback] Alot of things are going to effect your exhaust note. Engine temp, wheather, humity, etc. The size and shape of your ports is no exception. All engines are different more or less, especially when you change them, they run best when a pipe is tune to them and the type of riding you do. If you want to make the most out of your exhaust have one custom built for your motor and type of riding. A custom built pipe built to your engine will run better than a mass produce pipe. Remember the mass produce pipe is shooting to be tune with a wider variations of motors. Now a custom pipe on a stock motor, maybe a waste of money over a mass produce pipe. Because you may not notice much of an increase over the mass produce pipe. But if your changing your exhaust ports, I guessing you have more extensive mods done, so a custom pipe will help to bring out your mods better. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 12, 2005 Report Share Posted December 12, 2005 (edited) Thanks for the little info snippet there Mac Dizzy. (Go check that site out, looks pretty like a copy and paste job) When is the sex change scheduled? Edited December 12, 2005 by BigRed350x Quote Link to comment Share on other sites More sharing options...
cutiegirlracing Posted December 12, 2005 Author Report Share Posted December 12, 2005 Thanks for the little info snippet there Mac Dizzy. (Go check that site out, looks pretty like a copy and paste job) When is the sex change scheduled? 447625[/snapback] I'm sure Mac Dizzy, along with several sites out there, say the same thing. But I got this information, from a guy who used to race 2 stroke chain saws. Make's you wonder if there is a competition for weed eaters too. Quote Link to comment Share on other sites More sharing options...
rocketboy Posted December 12, 2005 Report Share Posted December 12, 2005 dude ,its not transvetitejetskiheadquarters.com . we already know all this copy/pasted info here and its been posted a zillion times friend ,i have a few unansewered questions that need addressed though . 1) do you fuckin even own a banshee ? 2) do you sit down to pee? 3) do yo u own a dick, clitoris, or both ? 4) why do you repeatedly post on jetskiing, when its bansheeHQ? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 12, 2005 Report Share Posted December 12, 2005 dude ,its not transvetitejetskiheadquarters.com . we already know all this copy/pasted info here and its been posted a zillion times friend ,i have a few unansewered questions that need addressed though .1) do you fuckin even own a banshee ? 2) do you sit down to pee? 3) do yo u own a dick, clitoris, or both ? 4) why do you repeatedly post on jetskiing, when its bansheeHQ? 447685[/snapback] Ha Ha Ha! You're not going to impress anyone around here cutiegirl. How about some pictures or a link to an official website of this chainsaw racing person? I know if I had a friend like that, I would have some pictures of them. Quote Link to comment Share on other sites More sharing options...
350TwinDeathBed Posted December 12, 2005 Report Share Posted December 12, 2005 (edited) dude ,its not transvetitejetskiheadquarters.com . we already know all this copy/pasted info here and its been posted a zillion times friend ,i have a few unansewered questions that need addressed though .1) do you fuckin even own a banshee ? 2) do you sit down to pee? 3) do yo u own a dick, clitoris, or both ? 4) why do you repeatedly post on jetskiing, when its bansheeHQ? 447685[/snapback] Yeah, this is getting fuckin old. If your tired, dudewannabeacutie, of the doubts we have about your female allegations, take a picture. It wouldn't be difficult for you to hop on that lowered blue Banshee with Paul Turners and do the shocker with your hand so we know it's you. Oh yeah you can stick your chest out too to show off your new set. Simple as that. Edited December 12, 2005 by 350TwinDeathBed Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted December 12, 2005 Report Share Posted December 12, 2005 We will all look like a bunch of asses if this person comes back with a picture of a gorgeous girl sitting on a lowered banshee doing the shocker. Quote Link to comment Share on other sites More sharing options...
Brooke Posted December 12, 2005 Report Share Posted December 12, 2005 We will all look like a bunch of asses if this person comes back with a picture of a gorgeous girl sitting on a lowered banshee doing the shocker. 447750[/snapback] wouldnt make her any less annoying and desperate. "look at meeeee im a giiirl i have huge fake booobs look at meee i like pink banshees i say stupid stuff like 'roded' unless im talking about engines then my IQ is suddenly 100 points higheeerrrr!!!!!!!" Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted December 12, 2005 Report Share Posted December 12, 2005 wouldnt make her any less annoying and desperate. "look at meeeee im a giiirl i have huge fake booobs look at meee i like pink banshees i say stupid stuff like 'roded' unless im talking about engines then my IQ is suddenly 100 points higheeerrrr!!!!!!!" 447753[/snapback] LMFAO I can almost hear the squeaky cheerleader voice. Go team. Quote Link to comment Share on other sites More sharing options...
