bansheeryder21 Posted December 7, 2005 Report Share Posted December 7, 2005 Got an 04 banshee with T-5's, K&N, NOSS head, 20cc domes. What size carbs should I get? I was thinking 28mm but I am not sure. I want my bike to be faster, but I want it to be reliable too. I ride mostly dunes and a little drag! If I get new carbs, should I get new reeds too? Please help! Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted December 7, 2005 Report Share Posted December 7, 2005 reeds-yes new carbs-not really Unless your ported, stock carbs ,though they are junk, should be fine Reeds are a pretty good mod. You would like em'. Get your flywheel lightend at the same time. Then that sucker will wind-up in a heart beat Quote Link to comment Share on other sites More sharing options...
odaen Posted December 7, 2005 Report Share Posted December 7, 2005 28's would be a good size. reeds may pickup a HP or 2, and should give you some better throttle response. Quote Link to comment Share on other sites More sharing options...
99Banshee Posted December 7, 2005 Report Share Posted December 7, 2005 I would'n get 28m carbs.. i would ate and do some porting and other mods and then get carbs..imo Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 7, 2005 Report Share Posted December 7, 2005 We put bigger carbs on all the time on stock ported bikes . I would say 33 pwks would help power everywhere and your throttle response. You say your duning and light dragging so go for it. V force reeds will also help out your response and give 1-3 hp. When you do decide to port it you will already have one up. Dont be skeered , you will love it! Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted December 7, 2005 Author Report Share Posted December 7, 2005 We put bigger carbs on all the time on stock ported bikes . I would say 33 pwks would help power everywhere and your throttle response. You say your duning and light dragging so go for it. V force reeds will also help out your response and give 1-3 hp. When you do decide to port it you will already have one up. Dont be skeered , you will love it! 445957[/snapback] So you think I should get the 34mm? Is that okay with my stock porting? What if I got reeds before carbs, would I notice a big change with just reeds? Because I know reeds are alot cheaper than carbs are! I want more power, but I don't want to spend an arm and a leg doing it! How much are the carbs anyway? Quote Link to comment Share on other sites More sharing options...
rocketboy Posted December 7, 2005 Report Share Posted December 7, 2005 theres some dyno charts posted awhile back by member banchetta and the effects of putting bigger carbs on a unported banshee and various mods ,it should significant loss and iMO youd be better off getting the 30mm oko carb set from carb parts warehouse in Ohio that sel l on ebay for 185$ w/ all the jets ,lines ,and goodies . you need a strong port job to flow the 33pwks or 34 mm pjs on a 350 IMO , otherwise youll likely lose power ,dont over carb your bike ,carbs dont add a shit load of hp anyways ,get your shit ported instead Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 7, 2005 Report Share Posted December 7, 2005 Porting well definetly pick it up the most !!! 30s or 33s PWK will help some and will help the response over the stock round slides carbs! The v force will help just a couple of hp. I wouldnt recommend going over 33s though. The porting will pick up a bunch more HP and will run about what the carbs do $! Do you have a timing plate yet? That would be a good gain of about 2 hp for cheap! Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted December 10, 2005 Author Report Share Posted December 10, 2005 I think I am going to go with the CPW 30mm carbs. Does anyone out there have that set up? Let me know what you think! I have heard that bigger carbs give you a lot more power. I would do a port and polish but don't have the money right now! $$$ Quote Link to comment Share on other sites More sharing options...
crank67 Posted December 10, 2005 Report Share Posted December 10, 2005 i would get pj 34 carbs i love them good allaround carb i got 3 sets ov them had 28 34 36 39 and 34 are the best all around carb for the monney Quote Link to comment Share on other sites More sharing options...
rocketboy Posted December 10, 2005 Report Share Posted December 10, 2005 I think I am going to go with the CPW 30mm carbs. Does anyone out there have that set up? Let me know what you think! I have heard that bigger carbs give you a lot more power. I would do a port and polish but don't have the money right now! $$$ 447099[/snapback] i used to and i liked them alot ,member silverback uses them and likes them also Quote Link to comment Share on other sites More sharing options...
odaen Posted December 10, 2005 Report Share Posted December 10, 2005 they are basically a 28pwk knockoff that's been bored to 30mm right? Quote Link to comment Share on other sites More sharing options...
Wallrat Posted December 10, 2005 Report Share Posted December 10, 2005 Porting prices start at about $200 and will give you way more power than just changing the carbs. Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted December 10, 2005 Author Report Share Posted December 10, 2005 Porting prices start at about $200 and will give you way more power than just changing the carbs. 447168[/snapback] Where can I get my bike ported at? I live in San Diego. I notice you're in OC. Also what stage you recommend for me? I want my bike fast but reliable! Quote Link to comment Share on other sites More sharing options...
Wallrat Posted December 10, 2005 Report Share Posted December 10, 2005 Jeff at FAST is popular, so is PassionRE. Alot of folks also like Eric Gorr. I had my porting done by a local builder. Custom Creations up in Riverside area. I've got a mild dune port which gave me gains top to bottom, mostly in the mid to upper range. I'd stay away from Trinity but thats up to you. http://www.customcreationsatv.com/ Quote Link to comment Share on other sites More sharing options...
