aguita Posted December 6, 2005 Report Share Posted December 6, 2005 I have stock gearing 14/41 today i was checking my front sprocket and i found that is missing 2 teeth!..so it has 12! it is ok to run like this? or if i get a new 13T sprocket will i see a difference noticeable on acceleration?? thanks Quote Link to comment Share on other sites More sharing options...
bansheeryder21 Posted December 6, 2005 Report Share Posted December 6, 2005 So you have a 14 front sprocket with only 12 teeth? You should definetly get a new sprocket. You could throw your chain if you leave that broken one on. If you want more acceleration, than yes get a 13 tooth sprocket. I ride in sand and it helps me out a lot. it gave me alot more torque thru all my gears. The only thing that sucks is when I ride in dirt, I get way too much tire spin! Good luck! ps: that sprocket only cost about $10-$15. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted December 6, 2005 Report Share Posted December 6, 2005 I have stock gearing 14/41 today i was checking my front sprocket and i found that is missing 2 teeth!..so it has 12! it is ok to run like this? or if i get a new 13T sprocket will i see a difference noticeable on acceleration?? thanks 445715[/snapback] If you actually broke off 2 teeth I wouldn't run it you risk throwing the chain off. If it's just a 12 tooth to begin with you're fine. If yours was a 14 you'll gain a touch of accelleration going to the 13 and a little top speed, you might also add some tire spin and in return loose some acceleration though. If you had a 12 you'll loose a touch of accelleration going to the 13 but gain some speed, and it should slip less. Quote Link to comment Share on other sites More sharing options...
aguita Posted December 7, 2005 Author Report Share Posted December 7, 2005 HEYY!!! WILL A WARRIOR FRONT SPROCKET FIT MY BANSHEE!!???? CUZ THE WARRIOR one is 13T and i have one almost new and i can get it for free! i saw on alba action that they banshee ones fit warrior and vice versa!? Quote Link to comment Share on other sites More sharing options...
Rooster Posted December 8, 2005 Report Share Posted December 8, 2005 Remember, if you're replacing the front sprocket you should replace the rear one too, and the chain. If you just replace one item you stand a big chance of snapping the chain, and that's not a good thing, trust me. Rooster Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 8, 2005 Report Share Posted December 8, 2005 impretty sure those sprockets are the same. you can always order from RMATV. primary drive sprockets are about 7 for thefront and 15 forthe rear. def buy a new one at least. and maybe even go to 13 if u wanna try it. theyare only 7 bucks.. Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 9, 2005 Report Share Posted December 9, 2005 Go ahead and buy a couple of different sizes and see what you like best. Quote Link to comment Share on other sites More sharing options...
ozosborne Posted December 9, 2005 Report Share Posted December 9, 2005 What set up do most of you guys use? And with just a few mods can I run the same, I'm looking for more top end and less wheel spin? Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted December 9, 2005 Report Share Posted December 9, 2005 I'm running a 14/40 in the sand, and it pulls my 10 paddle haulers just fine, but I've got quite a few mods also. Quote Link to comment Share on other sites More sharing options...
aguita Posted December 9, 2005 Author Report Share Posted December 9, 2005 i use my shee on drag more than in sand..i just put my warrior 13t sprocket on front..i can fell some more torque but the engine pulls needs a higher gearing cuz it feels that it has more speed to build up ..so i guess im going 15-41--what setup could be fine.. Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 11, 2005 Report Share Posted December 11, 2005 With stock 14-41 gearing I felt like I wound out to early, then I put on 15-41 and got less wheel spin and gained a lot of top speed. Now I'm running 15-42 and have a little better bottom and enough top end left to. Quote Link to comment Share on other sites More sharing options...
righteyeblind Posted December 11, 2005 Report Share Posted December 11, 2005 Put a 13/43 on your bike and in the sand you will blow the doors off people. I have sst's with a 2-1 ait filter kit and I smoke big bored yfz's all day banshees with cool heads and toomeys. IT is the way to go! Quote Link to comment Share on other sites More sharing options...
aguita Posted December 11, 2005 Author Report Share Posted December 11, 2005 i dont ride @ dunes..i mostly do trails,and drag ...so..i was thinking going 15-41? how does this sounds?? Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 12, 2005 Report Share Posted December 12, 2005 If you want to drag gear it to start off in 2nd. 1st is a waste in drag because you have to shift to early and take the chance of hitting neutral. Quote Link to comment Share on other sites More sharing options...
jjfizzle51 Posted December 12, 2005 Report Share Posted December 12, 2005 yes you will notice a hell of a diffrence in acceleration well wheel spin at least. i would defenitly get the 13 tooth for dunes, but if you ride hard pack most the time stick with 14 tooth way to much wheel spin on hard pack with the 13 tooth Quote Link to comment Share on other sites More sharing options...
