fabricated Posted December 1, 2005 Report Share Posted December 1, 2005 I know that genuine yamaha pistons are the ones to find but they are just too expensive. Other then those what would be a really good set of pistons. I am thinking about buying some wisecos. Quote Link to comment Share on other sites More sharing options...
stclark816 Posted December 1, 2005 Report Share Posted December 1, 2005 I am thinking about buying some wisecos. 443736[/snapback] Good call. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 1, 2005 Report Share Posted December 1, 2005 I know that genuine yamaha pistons are the ones to find but they are just too expensive. Other then those what would be a really good set of pistons. I am thinking about buying some wisecos. 443736[/snapback] yamaha pistons are junk, ive seen them fall apart for no reason.. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted December 1, 2005 Report Share Posted December 1, 2005 Pro-x pistons are the only stock replacement pistons I would consider, if not those then go wiseco's. Rebore's will come a little more frequently using wiseco's. Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted December 2, 2005 Report Share Posted December 2, 2005 wiseco's. Has anyone ever run these? http://cgi.ebay.com/ebaymotors/YAMAHA-BANS...593187743QQrdZ1 i will be the guinea pig if i have to. I would also like to run dyno runs back to back against wiseco's or pro-x and these "ported" pistons. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted January 26, 2006 Report Share Posted January 26, 2006 For performance go with the wiseco, if your looking for somthing with longer life try Pro-X Had my Pro-X for 2 seasons now and still look great. but loose alittle HP Quote Link to comment Share on other sites More sharing options...
squish Posted January 28, 2006 Report Share Posted January 28, 2006 namura is good. Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted January 28, 2006 Report Share Posted January 28, 2006 Pro-x pistons are the only stock replacement pistons I would consider, if not those then go wiseco's. Rebore's will come a little more frequently using wiseco's. 443766[/snapback] Why is that? Factory Yammy pistons are cast, don't buy these!, Wiseco pistons are forged and have a thicker ring for longer life. With a forged piston you will have to run a 3-4 thou. clearance. The numura pistons move the port window to change where the powerband comes in, I belive they are also forged. I don't know about those German ebay pistons, look a little sketchy to me? and I don't think you will see a power differance between pistons unless the windows or domes are altered, Wiseco uses oem dome heights. I would go with the Wisecos, they have been doing it a long time and are readily available! Quote Link to comment Share on other sites More sharing options...
