can i buy a new factory frame
peterlocal22
how hard is it to swap out frames?  Ive craked the subframe twice now and I got a few stress cracks up by the gas tank....and Im just waitin for the day Im gonna have to start weldin and gussetin.
441767[/snapback]
Pretty simple, if you have everything ready (tools, new bolts if necessary...) it's just a good afternoons worth of work. When I did mine the parts went from the old frame straight to the new frame so I didn't get them confused. You'll need to have something to take out the retainer for the steering stem bearing, I used a bolt that I got at the hardware store do a search on here for the size I know I posted it but I can't recall what it was right now. Make sure you have a clymers handy incase you can't figure something out, the HQ is always here to answer any other questions too. :cheers:
  • 1 month later...
i had a buddy wad up on a tree and bend his frame. he had the local dealer order and install a new frame. when he picked it up the mechanic handed him the section of frame with the vin off his old frame. handed the pipe to him and said keep this its all the proof you have that this quad is yours
  • 4 weeks later...
I'm pretty sure that the new ones that you get from the dealer do not have a serial number on them.  As far as registering them, I guess you would just use the serial number from the original frame, or you might see if you can use the numbers that are on the side of the motor.
441518[/snapback]
all my frames are direct factory ones , no numbers , never registerd , and there powdercoated .
so i guess the answer is , no numbers if u buy direct from factory
