23champ Posted November 26, 2005 Report Share Posted November 26, 2005 If the dirt is moist at the starting line the wedges will hook twice as hard as paddles. That will give you the speed at mid track to let the tires keep hookin all the way to the finish line.. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted November 26, 2005 Author Report Share Posted November 26, 2005 (edited) Yeah at the start it is very moist as the water truck goes over it. But at the start of the day the start line is almost sloshy mud. Would the "snows" be able to get out of it or will they spin? And if i decided to get some 4-snows, what size tire and rim do u recommend as the best for drags? P.S Would anyone have a movie clip of a banshee dragging with Wedges or Snow's? Edited November 27, 2005 by 420_Big_Bore Quote Link to comment Share on other sites More sharing options...
23champ Posted November 28, 2005 Report Share Posted November 28, 2005 the lightest weight (.125) 8" wheel is best for drag Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 1, 2005 Report Share Posted December 1, 2005 The pro wedge or 4 snows do well on hard pack clay, and they help you with running a gear longer on top because they ballon up. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted December 13, 2005 Author Report Share Posted December 13, 2005 So for medium-hard paked clay (at the start it is moist and loose), would you recommend 4-snows over sumthin like Razr II's or Kenda Dominators? Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 16, 2005 Report Share Posted December 16, 2005 The 4 snow is an awesome drag tire soft or hard surface, you can adjust your air pressure depending on traction. The razr type tires are great for trail riding and mx but not the best drag tire. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted December 16, 2005 Author Report Share Posted December 16, 2005 Ah Ok What about the pro wedge II tire, i know there similar to the 4-snow but harder tread. Would these be my best choice as i have the chance of getting a set of the Pro Wedge II's. Quote Link to comment Share on other sites More sharing options...
23champ Posted December 16, 2005 Report Share Posted December 16, 2005 do it! Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted December 17, 2005 Author Report Share Posted December 17, 2005 Thanks, i will. So these tires will definitely give me more traction than i have now with the Kenda Dominators? Quote Link to comment Share on other sites More sharing options...
banshee tuner Posted December 18, 2005 Report Share Posted December 18, 2005 Yes these will give you more traction, run them backwards to where the tread is biting not cleaning and play with the air pressure. These are good for straight line running, keep your other tires for riding and sliding curves cause that is the advantage of the flat tires. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted December 19, 2005 Author Report Share Posted December 19, 2005 (edited) I've never heard to run a tyre backwards, but thanks for your help. The drag meeting is on 21st Jan. so i will let u know how i went. Thanks again!!!!! Edited December 19, 2005 by 420_Big_Bore Quote Link to comment Share on other sites More sharing options...
race-a-holic Posted December 19, 2005 Report Share Posted December 19, 2005 Yes,run them backward.Let us know how you do in the race. Quote Link to comment Share on other sites More sharing options...
da_man02 Posted January 14, 2006 Report Share Posted January 14, 2006 just jumped in on this. how much power is your bike making? if you got somewhere around a stock motor with pipes and just some minor bolt-ons you'll probably be better off running a radial tire like what comes stock on a raptor and the z400's. with the 4-snow's and pro wedges they grow at the other end and if you bike doesn't have enough power they will pull the motor down (bog). if you do have enough motor to run some different tires then 4snows or pro wedges are definately what you want to go with. look at different pictures of drag bikes on this forum and other forums and you will notice that they have these tires. hope this helps. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted January 16, 2006 Author Report Share Posted January 16, 2006 No my bike is putting out enough power, thats why i am changing tires. I have a 420 big bore kit, 34mm carbs, stge II port job, GRR drag pipes, and alot of minor mods aswell. Thanks for your advice. Quote Link to comment Share on other sites More sharing options...
420_Big_Bore Posted March 13, 2006 Author Report Share Posted March 13, 2006 Hi guys i have bought my pro wedge 2s, and now are ordering a set of rims. I have ordered some 8x8 red label douglas rims which are (.190). I know that ppl have been recommending (.125) but this is all i can get. Are the red labels ok, or bad. Thanks Quote Link to comment Share on other sites More sharing options...
