axle nut wrench size?
quad4me
I believe it is a 50mm. I got a wrench from dennis kirk while back.
Made by motion pro. Put it on there and hit it a couple times with
a BFH and its off and on in no time.
439823[/snapback]
50mm is correct as far as I can tell..you can order the motion pro set of wrenches from a few diff sites @ about $34. >>looking like I wil use a pipe wrench!
Thanks!!!
if you buy the right tool for the job, you can use your torque wrench with the adapter and tighten the nuts the right way so that they do not back off. when I changed my swinger I used a big cresent wrench the first time and the nut backed off, so the second time I copyed the wrench I needed and torqued the nuts the right way and they have not moved. better for setting bearing preload also.
