Good info RATBIKE0130 , that is how I thought the cubs were.  You shouldn't need custom domes, just bigbore domes if your using the 68mm bore.
What would be the advantage of running the 795 series banshee pistons (65mm bore) if you have a long rod or stroker long rod crank? Wouldn't you always be better off with the blaster pistons (68mm bore) due to the larger displacement and bigger port windows in the piston?
444177[/snapback]
You have to run 795's in the 65mm bore version because the blaster pistons start at 66mm bore wich is standard bore.
444554[/snapback]
Yes, I knew that. What I was trying to ask is why would you choose the smaller bore cylinders over the larger. Is there any advantage or power characteristic to the smaller bore cylinders? You have to buy one or the other, why would you buy the smaller bore cylinders?
