bansheefreestyler Posted November 7, 2005 Report Share Posted November 7, 2005 hey guys. the salesman at yamaha said to adjust the valves after 20 hours of riding on my yfz. whats the purpose of this and will it matter if i dont? if it does then how do i do it and is it hard? how many other times do you have to do it? Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted November 7, 2005 Report Share Posted November 7, 2005 Time for the service manual. Yes you need to adjust the valves. If you don't it will slowly screw over your new bike. Just do the service. They have services like that scheduled for a reason don't you think? It's not hard to to at home if you have the manual andsome good tools and a clean shop and know what you are doing. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 7, 2005 Report Share Posted November 7, 2005 ive had mine almost 2 years and never ad the valves adjusted..just gonna put a new piston in it this week..i run the shit out of mine and never had any problems... Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted November 7, 2005 Author Report Share Posted November 7, 2005 well ill take it to my mechanic and get him to do it since he is going to be putting my pipe on and jetting it for me and other stuff so ill just get him to do it Quote Link to comment Share on other sites More sharing options...
Gargamel Posted November 7, 2005 Report Share Posted November 7, 2005 The service schedule is worded wrong. It should say CHECK the valves. It is a luck call if you don Quote Link to comment Share on other sites More sharing options...
Ducman Posted November 7, 2005 Report Share Posted November 7, 2005 If you ride it hard then I would check the valves in about 20 hours or so, if you aren't punishing it then it could go longer. I had my wifes done by the dealer at 20 hrs just because we got an extended warrenty that covers the motor for 2 years and if was an F'en rip off; $180 for labor. Definitely change the oil and filter right after break in yourself. A friend of mine just got a uses 05' YFZ and did the exhaust cam mod the first week of owning it with just instructions I printed for him that I got off YFZcentral, and he said it was pretty easy so I'd guess that checking the valve clearance would be pretty easy too. Get a manual, and you'll probably need some specialized feeler guages and then need to order the correct shims if they are out of spec. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 7, 2005 Report Share Posted November 7, 2005 well ill take it to my mechanic and get him to do it since he is going to be putting my pipe on and jetting it for me and other stuff so ill just get him to do it 434091[/snapback] Dude, you will spend a small fortune to pay someone to do it. The pipe and jetting is EASY to do...Pipe takes about 10 minutes to install and jetting it isn't much more. You only have to take 1 screw out the bottom of the carb to get to the main jet, and I believe it's only 3 screws at the top of the carb to change the needle. I've never adjusted the valves in mine and I've put a solid 40-50 hours on the 450...runs perfect. You can do it freestyler!!!! Quote Link to comment Share on other sites More sharing options...
Wallrat Posted November 7, 2005 Report Share Posted November 7, 2005 No way in hell can you install a pipe and jet kit in under 30 min. It takes a good 15-20 just to remove the tank and plastics to get at the carb. Agreed it ain't hard, but it will take some time to do. Quote Link to comment Share on other sites More sharing options...
Ducman Posted November 7, 2005 Report Share Posted November 7, 2005 No way in hell can you install a pipe and jet kit in under 30 min. It takes a good 15-20 just to remove the tank and plastics to get at the carb. Agreed it ain't hard, but it will take some time to do. 434183[/snapback] No, you can just loosen the clamps on both sides of the carb and rotate the carb to get at the jets. Take the hex nut cap off the bottom of the bowel and you can access the main and pilot jet, 2 screw to take off the top cover to access the needle. You can change the pilot and main in 10 minutes and the needle in another 10 min. You don't need to take off any plastic. Just need to disconnect the fuel line. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 7, 2005 Report Share Posted November 7, 2005 It takes a good 15-20 just to remove the tank and plastics to get at the carb. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted November 7, 2005 Report Share Posted November 7, 2005 You need to add in find your tool time, find the dropped nut time, find the lost screw time, damn I should have put something under that carb to catch the gas time, oh shoot I hope I didn't just strip that thread time and the time it takes to remember you forgot to do something time. The sum of these times can amount to anything from an additional 10 min to 3 days. Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted November 7, 2005 Author Report Share Posted November 7, 2005 Dude, you will spend a small fortune to pay someone to do it. The pipe and jetting is EASY to do...Pipe takes about 10 minutes to install and jetting it isn't much more. You only have to take 1 screw out the bottom of the carb to get to the main jet, and I believe it's only 3 screws at the top of the carb to change the needle. I've never adjusted the valves in mine and I've put a solid 40-50 hours on the 450...runs perfect. You can do it freestyler!!!! 434147[/snapback] haha i get it done for free now. he does all the labour for free cause he pastures his horses at my place and he pays for that too Quote Link to comment Share on other sites More sharing options...
98bonerSTOCKshee Posted November 7, 2005 Report Share Posted November 7, 2005 damn... I forgot you got the 4 stroker I read the title and thought, " BFS is a retard".. Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted November 8, 2005 Author Report Share Posted November 8, 2005 ahhaha nah man im not that stupid Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted November 8, 2005 Report Share Posted November 8, 2005 haha i get it done for free now. he does all the labour for free cause he pastures his horses at my place and he pays for that too 434234[/snapback] Can't argue with that!! Hurry up and get that pipe put on...we need more vids Quote Link to comment Share on other sites More sharing options...
