no fire
im having same problem my plug has fire also but right cylinder not firing,i started it one day and it screamed let it set for a while went back to start it and it started missing on the rightside weve checked everything we could still nothing tore it down and the rings and piston is perfect,well the only thing i can think of is the stator we changed the flywheel and the crank seals after that this problem started the day we done it,it was very hard to start but when it started it missed on the rightside for just a minute then both cylinders were firing normal but each day it kept getting worse,ive read every post on this site and planet sand and the same oh stuff check your plugs,swap carbs,swap reeds,check caps,check stator,air leak,crank seals ive tried it all so know im gonna put new rings and pistons and try that hope to god it works but i doubt it hope you find out for both are sake thanks if i can help just email me at moviesnmore@hotmail.com or pm me on here or planetsand my screen name is the same
Hey...DS...
He last posted that problem in November of 05...I hope he has it sorted by now...:)
:beer:
