Noss Head
DIRTMAN350
Hi,
Is it nessacary to use the supplied nuts and washers that come with my noss head? I couldn't use them due to the fact that my head studs stick up a little bit too far. I used my stock nuts over. Haven't rode it yet but i hope coolant does not wick up around the studs. Latter and ride safe.
You don't have to use the acorn nuts. Sometimes they do bottom out on the studs. I guess the studs aren't always the same length. I'm looking for some different ones that are deeper but haven't had any luck yet. If anyone has a source for stainless metric acorn nuts, let me know.
Put a little RTV on the threads if you have any coolant pushing up through the studs.
432991[/snapback]
Dave, they have them here. LINK
dawarriorman,
Thanks.
They are 8mm X 1.25 pitch. I'd like them to have about 15mm thread depth. I buy them 1000 at a time.
RNBRAD,
Thanks, I'll call them tomorrow. I can't navigate their site.
Ok, called them up today, and they do have some, but they're only 3/16" deep. The guy I talked to wasn't sure if they could order anything different, but I think they would be able to at that quantity. He said they order 100 at a time (acorn nuts aren't a big seller), and they would be about $20 per 100. Their number is 1-800-476-BOLT (2658).
Edited by dawarriorman
