sheecandy Posted November 3, 2005 Report Share Posted November 3, 2005 i was contemplating using my sst pipes with my newly dune ported cylinders from racers edge tryed the shee out this weekend at glamis runs great got some kick ass low and mid range pull signs off a little early compared to my 00 old dune port and pro circuits happy with my new set up :dance list of mods dune port stock bore sst pipes stock carbs clamp on k&ns 350 mains v-force reed valves +4 degree key racers edge cool head 20cc domes skat trak haulers Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 3, 2005 Report Share Posted November 3, 2005 I thoguth you were supposed to bore and hone your cylinders after porting ? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 4, 2005 Report Share Posted November 4, 2005 SSTs work great with dune/play port! If ya need more top end without sacrifising much bottom end try some 35pwk Air Strykers!! Give me a holler when your ready for them.... Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 4, 2005 Report Share Posted November 4, 2005 SSTs work great with dune/play port! If ya need more top end without sacrifising much bottom end try some 35pwk Air Strykers!! Give me a holler when your ready for them.... 433135[/snapback] wouldent 33mm PWK's work better with a non stroked motor? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 4, 2005 Report Share Posted November 4, 2005 Not in our case. Both are very good way to go. Quote Link to comment Share on other sites More sharing options...
kotin6 Posted November 12, 2005 Report Share Posted November 12, 2005 i have pretty much the same set up and Im in the SSTS work great, you do however need bigger carbs, Im in the market for a 33mm set up my self so fast hit me up. Quote Link to comment Share on other sites More sharing options...
