Turbobanshee_kid Posted November 3, 2005 Report Share Posted November 3, 2005 I have $300, I have stock reeds should I get V-force 2 or A noss machine cool head with 21cc domes? If I got 20cc domes would I have to welded the crank? I have 1.00mm over bore pistons right now. Should I get the reeds first? THANK YOU GUYS! Quote Link to comment Share on other sites More sharing options...
Turbobanshee_kid Posted November 3, 2005 Author Report Share Posted November 3, 2005 I am at sea level! 21cc domes would give me 156 and 20cc domes would give me 169 http://www.nossmachine.com/banshee_heads.htm Quote Link to comment Share on other sites More sharing options...
speedfreak350 Posted November 3, 2005 Report Share Posted November 3, 2005 stick with pro-design, you should have your crank welded any was eventually it will seperate no mater what you do to the bike. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted November 3, 2005 Report Share Posted November 3, 2005 I would go with the Reeds. Will give you a little better throttle response. Do the head later when you have some more mods. That's just me though. Everyone is different. I went with reeds first, then head. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted November 3, 2005 Report Share Posted November 3, 2005 (edited) Neither will make much of a HP difference, and definately not the head... The head will make your engine run cooler and give you more lowend if you get the correct domes. I also like the O-ring concept better than the gasket style. The Reeds will make your throttle response more snappy and might add a HP or 2. Personaly I would do the head first, and do the reeds when you change your carbs to something better down the road. Edited November 3, 2005 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
dlnoss Posted November 3, 2005 Report Share Posted November 3, 2005 You don't need your crank welded for 21cc or 20cc. I run 19cc with a stock crank. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted November 3, 2005 Report Share Posted November 3, 2005 The head will make a more noticable difference in HP. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 3, 2005 Report Share Posted November 3, 2005 For $300.00 we could hook you up with a Pro Design or a Noss head and a timing plate for advancing your timing and that will definetly help your HP needs!! A bone stock Banshee should have the crank welded as i have seen them come apart even in stock form ! Quote Link to comment Share on other sites More sharing options...
speedfreak350 Posted November 3, 2005 Report Share Posted November 3, 2005 For $300.00 we could hook you up with a Pro Design or a Noss head and a timing plate for advancing your timing and that will definetly help your HP needs!! A bone stock Banshee should have the crank welded as i have seen them come apart even in stock form ! 432727[/snapback] yeah they will come apart so do it before its too late, also go with the timing plate it helps alot, and go withthe pro design like i said before. Quote Link to comment Share on other sites More sharing options...
Turbobanshee_kid Posted November 3, 2005 Author Report Share Posted November 3, 2005 I have the $80 timing plate I think I am going to weld the crank to for $50 At a local shop? And get reeds! Should I get V-force 2 or 3's I plane no getting porting and cool head! I have 1.00mm over bore pistons and T-5's and timing plate and boost bottle. Quote Link to comment Share on other sites More sharing options...
odaen Posted November 3, 2005 Report Share Posted November 3, 2005 yikes, the timing plates are $35. you could get material taken off your head and a new set of reeds for your $300. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted November 3, 2005 Report Share Posted November 3, 2005 If you do decide to get a head do yourself a favor and get a NOSS head. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted November 3, 2005 Report Share Posted November 3, 2005 If you do decide to get a head do yourself a favor and get a NOSS head. 432755[/snapback] Second! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 3, 2005 Report Share Posted November 3, 2005 id get NOSS and VF2 Quote Link to comment Share on other sites More sharing options...
super88_banshee Posted November 3, 2005 Report Share Posted November 3, 2005 yikes, the timing plates are $35. 432752[/snapback] Haha, mine was free cuz i did it myself! Quote Link to comment Share on other sites More sharing options...
