Who uses Castor 927?
i have run maxima 927 for 5 years. never had a engine failure. even after 500 hours on my pistons, there was still hone marks in the cylinders. it is good stuff. i run 44 :1 with pump premium gas.that stuff will seperate from the fuel in temps below 32 degrees. so watch out in the winter time after the gas has set. make sure you shake it up and remix it.
927 is probably the best oil available, Ive used it for over 20 years. Just make sure to keep your cans shaken before fueling(everytime) and if the cans sit for more than a week shake them extra good. It also helps to run your carbs dry after your done riding for the day, otherwise you will be extra rich on oil the next time you fire up. 40-1 is more than enough protection with 927...Jim
430991[/snapback]
yeah what he said.
