jeepman380 Posted October 21, 2005 Report Share Posted October 21, 2005 Why do you use just Type F ATF? All automatic trannys are wet clutches so I don't see why Type F is the only one that works. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted October 21, 2005 Report Share Posted October 21, 2005 Why do you use just Type F ATF? All automatic trannys are wet clutches so I don't see why Type F is the only one that works. 428215[/snapback] Pretty much all the other ATFs have the same friction modifiers that the oils do. Type F is doesn't, and lets the clutch hook up good. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted October 23, 2005 Report Share Posted October 23, 2005 i think you got that backwards type f has the friction modifiers and the others don't.thats what i was told back in the early days when i was driving 50's,60's and 70's fords. Quote Link to comment Share on other sites More sharing options...
wesw Posted October 23, 2005 Report Share Posted October 23, 2005 pops is correct when i had my ol 84 gmc with a some what of a shift kit, if i ran type f fluid it would get a second gear scratch but with dexron mercon it was sloppy shifting. type f is the stuff to use Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted October 23, 2005 Report Share Posted October 23, 2005 damn wes you mean your agreeing with pops on this one. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted October 24, 2005 Report Share Posted October 24, 2005 type f is the stuff to use 428915[/snapback] Type F is what I use also, I have tried Gearsaver in the past and it worked good too. Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted October 25, 2005 Report Share Posted October 25, 2005 pops is correct when i had my ol 84 gmc with a some what of a shift kit, if i ran type f fluid it would get a second gear scratch but with dexron mercon it was sloppy shifting. type f is the stuff to use 428915[/snapback] Dexron Mercon is the old lady shift type fluid Chrysler type is the in between Type f is the firmest shifting auto trans fluid. I use type F in my 66 Chevelle. I was told however that if you have been using regular oil in your trans to keep using it until you change your clutch. Other wise it will prematurely fry the clutch when you change. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted October 25, 2005 Report Share Posted October 25, 2005 Dexron Mercon is the old lady shift type fluid Chrysler type is the in between Type f is the firmest shifting auto trans fluid. I use type F in my 66 Chevelle. I was told however that if you have been using regular oil in your trans to keep using it until you change your clutch. Other wise it will prematurely fry the clutch when you change. 429659[/snapback] Well I switched 2 years ago, and haven't had the least problem with my clutch yet. I wouldn't worry about switching. Quote Link to comment Share on other sites More sharing options...
