BAD LUCK OR WHAT?
BANJO
i blew a piston about 8 months back..
did a full rebuilt but only put new main bearings on the crank...
so it starts up first kick runs great 1hr later the lower rod bearing goes...
so i do another rebuild with a new hot rod crank.. put back togeather
starts up first kick.. runs great.. 1.5hrs later enigine completly lucks up
in 4th gear driving down the street.. now there was no sounds nothing perfect bike then crank locks up...
now im stuck with another freaked motor i gota fix again.. i havent drivin my shee for more then 3hrs in the last 3/4 of a year...
noss head21cc
fattys
35mm..cv.. 188main..
luck or what???
peace devin
On my last shee, i fcked the topend 3-4 times in a matter of a month, if I would have just taken the month I used to rebuild those 3-4 times, and bought a cub stroker setup, it wouldn't of ever happened again... might wanna think about how much you're going to put into it, or what its worth.
yes its the worst thing that can happen to a banshee guy..
and its all stupid shit that happens... this time my kick gear/spring poped out of place and the iner cluch washer came loose.. very bad luck but it should run once again tonight...
i hope that is...
peace devin
Stock cranks don't hold up too well and they aren't 100% rebuildable. Even if you replace the bearings, 9 times outta 10 you're gonna have some play/seperation issues that will lead to premature bearing failure. IMO its not worth trying to rebuild a stock crank. If it were me I'd pull it apart and replace the crank with a wiseco that's 100% rebuildable. Actually it was me and that's what I did, went with a stroker while I was at it too.
428106[/snapback]
x2
