Front Left Shock Making Noise
watkins
2 cents says it's the attaching bolts at either the top or bottom of the shock, remove both bolts and grease em up without making a mess in areas you can see, and put it all back together, you can even douche the rubber grommets at the ends of the shock with WD-40 just in case, same goes for the back shock, i finally figured out that the god awful squeak is the top shock mount, did the above steps and now i listen to everyone else's banshee squeak when they sit on it, lol
~Mark~
The noise is not normal and should be checked out before you ride again. It could be any number of things. The good new is there isn't that many parts involved. Take the shock off and move the arms around. As was suggested, grease the mounting points. If it continues to make that noise afterward then the shock is probably bad.
Shane
