Ryda85 Posted October 11, 2005 Report Share Posted October 11, 2005 hey guys i am looking to pick up a tm chain slider....whats the biggest front sprocket you can run with one. i thought it was a 15t but i thought i heard someone running a 16t with one. hey while we are on sprockets....what gear ratio should i run with my passion stroker? i was thinking 16-40 but if the slider wont fit, maybe a 15-38?? i ride mostly woods with some quick drags when it gets open. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted October 11, 2005 Report Share Posted October 11, 2005 (edited) If your talking about the swingarm slider (the one you have to take the swingarm off to replace with a stock unit), TM's website says it will accomodate 13-17 tooth front sprockets so you should be good with a 16. Are you riding flatter, more open woods. Those sound like tall gears you're pulling, but I ride on the west coast with tight, steep wooded areas, and shorter gearing is preferable. Sorry forgot to add link: http://www.tmdesignworks.com/xcart/custome...&cat=274&page=1 Edited October 11, 2005 by 2003LimitedBanshee Quote Link to comment Share on other sites More sharing options...
Ryda85 Posted October 12, 2005 Author Report Share Posted October 12, 2005 my fault....what i ment was a case saver. i have no clue where chain slider came from. Quote Link to comment Share on other sites More sharing options...
mike23 Posted October 12, 2005 Report Share Posted October 12, 2005 I run a 17 tooth with my case saver, no problem Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted October 12, 2005 Report Share Posted October 12, 2005 TM only claims their case savers will fit 12-15 tooth setups. I run a 13 no problem (obviously), and it sounds like you should be able to run bigger (mike23), so... http://www.tmdesignworks.com/xcart/custome...&cat=255&page=1 Quote Link to comment Share on other sites More sharing options...
mike23 Posted October 14, 2005 Report Share Posted October 14, 2005 sorry Ryda my casesaver isn't TM, looked at the wrong bike. Quote Link to comment Share on other sites More sharing options...
Ryda85 Posted October 14, 2005 Author Report Share Posted October 14, 2005 what kind is it? maybe ill just get one of those instead Quote Link to comment Share on other sites More sharing options...
mike23 Posted October 14, 2005 Report Share Posted October 14, 2005 (edited) http://alba.buyol.com/Item/28-413xx.htm My bikes in storage but I'm pretty sure it's this one. I called and they said it would accept any size sprocket. Edited October 14, 2005 by mike23 Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 14, 2005 Report Share Posted October 14, 2005 (edited) http://alba.buyol.com/Item/28-413xx.htm My bikes in storage but I'm pretty sure it's this one. Edited October 14, 2005 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
