ShOcK
KoStOnE
Since Im new to banshees and shit I wanna learn about them so what do you mean by rebuild your stocker. You mean jsut rebuild the stocks hock and it would be better then a 450 shock. Please aexplain.
Thanks alot bro
Andrew
422577[/snapback]
You could have Elka rebuild your rear stock hock?.....the front stock hocks belong in the trash can, replace those, and yes a rebuilt stock rear hock is better than a stock rear hock from a 225 ZFY......... :headbang::lol:
as long as any other shock probably, although the elka may last longer (???) but it's also 3x as much money...Rear shock housing is similar to aftermarket rear shocks on other quads...the internals are what suffer... It makes a pretty huge difference having your rear re-done...I was suprised..
if you planning to get an extended swinger do it at the same time so you only need to valve it once.
I feel it will likely last longer than stock, since they are using better internals.
Edited by Justintoxicated
