Dunsmoor86 Posted September 17, 2005 Report Share Posted September 17, 2005 I have work shocks and i am wondering how I should compress them so I can change the stiffness? I have tried a couple things but no such luck. Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted September 19, 2005 Report Share Posted September 19, 2005 You extend them to change spring settings. It takes as much tension as possible off the springs. Quote Link to comment Share on other sites More sharing options...
Gargamel Posted September 19, 2005 Report Share Posted September 19, 2005 if you dont have a welder to make a jig to do it I say the next best is just use a couple of pipe clamps and tightenthem down . If your just turning the adjustment nut on the shock then you should just need a spanner wrenchto turn it. Quote Link to comment Share on other sites More sharing options...
89Steeda Posted September 20, 2005 Report Share Posted September 20, 2005 Just catch the highest coil with one hook of a ratchet tie down, run the tie down around the end of the shock and back up to the highest coil(other side) that you can get it on.Crank the spring down. Slide the collar up to expose the big circlip. Move the circlip to the desired groove. Release the whole mess. Done. Quote Link to comment Share on other sites More sharing options...
