nick81 Posted September 16, 2005 Report Share Posted September 16, 2005 Ok I bought an 01 shee in a few pieces. I picked up the necessary parts to rebuild it from this site and ebay..and the dealer(rip-offs). Now when I try and start it, I get no spark. I tested the coil according to the haynes manual(it was confusing) and it failed so I bought a new one from the dealer. still no spark. So I got to thinkin about a ground wire issue. I remember, there are no ground wires that I can see. So, where are they? seems like I should probably make one or so to make sure Just wanna know where does it go. Like from where to where? Also, if I put a voltmeter on the wires that go on the coil terminals, I get voltage whenever I kick it over. So I think that everything is basically eliminated except the ground. Thanks Quote Link to comment Share on other sites More sharing options...
it's stolen Posted September 16, 2005 Report Share Posted September 16, 2005 the ground wire on my 94 is in the rear on one of the bolts that holds the voltage regulator to the frame Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted September 16, 2005 Report Share Posted September 16, 2005 All your black wires lead to the ground where it's stolen mentioned. Quote Link to comment Share on other sites More sharing options...
pimpeinkc Posted September 16, 2005 Report Share Posted September 16, 2005 how are you checking for spark, the coil could be bad, i know an indutive timeing light will help figure that out, boot could be bad. Quote Link to comment Share on other sites More sharing options...
