aguita Posted September 15, 2005 Report Share Posted September 15, 2005 hello guyz i just got my ratio rite thing..i have t5,filter,bored .025 with wiseco,timmng advance i use premium fuel on it..actually i use 3oz of oil per gallon..i really dont know how much is that..i just want to know which is the better ratio..the engine doesnt smoke only when cold and not too much then after that is clean..i use Repsol Competition synthetic ...thanks and yes i did search! Quote Link to comment Share on other sites More sharing options...
SAMUNOWAY Posted September 15, 2005 Report Share Posted September 15, 2005 I use Motul 800 @ 40:1 Quote Link to comment Share on other sites More sharing options...
FOXBANSHEE30 Posted September 15, 2005 Report Share Posted September 15, 2005 i run Yamalube 2-R Racing oil and i run 93 octane gas. The best way i have found is to fill up a 5-Gallon gas tank and then just add 16oz. of whatever oil you want to run and shake it up a lil and it wont smoke. Except for a lil at start up and while its warmin up. Always works great for me. I use to do the same with my Blaster before i upgraded it to a Banshee. MEADOWS. <<<CWB>>> Quote Link to comment Share on other sites More sharing options...
ke398 Posted September 15, 2005 Report Share Posted September 15, 2005 I run klotz 32:1 no problems ever. Klotz is awesome. You are running 42:1, seems a little lean in my opinion. Quote Link to comment Share on other sites More sharing options...
BansheeBillyBob Posted September 15, 2005 Report Share Posted September 15, 2005 i run 40:1 wit klotz wit no prob Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted September 15, 2005 Report Share Posted September 15, 2005 I run 80:1 but then again I run amsoil. Cleanest my engines ever been and no problems with it. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted September 15, 2005 Report Share Posted September 15, 2005 I have run everything from 16.1 to amzoil 100.1 and they all worked fine. I never had any trouble with any ratios as long as the bike was jetted for it. The amzoil made me nervous at 100.1 though especially on a LT 500. I now have been running Klotz at 40.1 for over 6 years ! Quote Link to comment Share on other sites More sharing options...
2strokesmoke Posted September 15, 2005 Report Share Posted September 15, 2005 i use amsoil interceptor at 40 to 1 and i mix 2 gallons of 112 to 1 gallon of 93 runs very clean 180 psi of compression Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 15, 2005 Report Share Posted September 15, 2005 i run 40:1 wit klotz wit no prob 415286[/snapback] same here...in 4 different bikes...for a long time now.. Quote Link to comment Share on other sites More sharing options...
Hadar Posted September 15, 2005 Report Share Posted September 15, 2005 I like 32:1 but then again I love to kill skeeters. A 2stroke that does not smoke at least a bit is not long for the world. Quote Link to comment Share on other sites More sharing options...
Ducman Posted September 15, 2005 Report Share Posted September 15, 2005 1gallon = 128 oz Divide 128 by the ounces of oil to get your ratio. 128/3 = 42.66667 so you are about 43:1 You need to mix your oil within the recommendations on the back of the bottle. Some oils are made to mix at 100:1, most mix in the 20:1 to 50:1 range. I think banshee's runs best at 40:1 with most oils. But alot of people like the Amsoil that you mix at 100:1. I run Maxima Castor 927 at 40:1, I like it because it smells sweet, runs good and clean, and is redily available at any motorcycle shop. Quote Link to comment Share on other sites More sharing options...
aguita Posted September 15, 2005 Author Report Share Posted September 15, 2005 ducman the oil doesnt recommend a mix ratio it says that use the ratio that the manufacturer recommeds so i guess 40.1 is the best rite Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted September 15, 2005 Report Share Posted September 15, 2005 i run castor and turbo blue at 40:1 Quote Link to comment Share on other sites More sharing options...
aguita Posted September 15, 2005 Author Report Share Posted September 15, 2005 also which way should i mix xylene i have some lying around and i have good results when using it on my car so can i mix the xylene 50/50 with gas our just pour an amount on the gas tank? Quote Link to comment Share on other sites More sharing options...
taldoc3 Posted September 15, 2005 Report Share Posted September 15, 2005 4 ounces per gallon to be safe, with yamalube or something equiviliant it will give you 40:1 Quote Link to comment Share on other sites More sharing options...
