Best Fuel Ratio
aguita
hello guyz i just got my ratio rite thing..i have t5,filter,bored .025 with wiseco,timmng advance i use premium fuel on it..actually i use 3oz of oil per gallon..i really dont know how much is that..i just want to know which is the better ratio..the engine doesnt smoke only when cold and not too much then after that is clean..i use Repsol Competition synthetic ...thanks and yes i did search!
i run Yamalube 2-R Racing oil and i run 93 octane gas. The best way i have found is to fill up a 5-Gallon gas tank and then just add 16oz. of whatever oil you want to run and shake it up a lil and it wont smoke. Except for a lil at start up and while its warmin up. Always works great for me. I use to do the same with my Blaster before i upgraded it to a Banshee. MEADOWS. <<<CWB>>> :dance:
I have run everything from 16.1 to amzoil 100.1 and they all worked fine. I never had any trouble with any ratios as long as the bike was jetted for it. The amzoil made me nervous at 100.1 though especially on a LT 500. I now have been running Klotz at 40.1 for over 6 years ! :)
i use amsoil interceptor at 40 to 1 and i mix 2 gallons of 112 to 1 gallon of 93 runs very clean 180 psi of compression
1gallon = 128 oz
Divide 128 by the ounces of oil to get your ratio.
128/3 = 42.66667 so you are about 43:1
You need to mix your oil within the recommendations on the back of the bottle. Some oils are made to mix at 100:1, most mix in the 20:1 to 50:1 range. I think banshee's runs best at 40:1 with most oils. But alot of people like the Amsoil that you mix at 100:1. I run Maxima Castor 927 at 40:1, I like it because it smells sweet, runs good and clean, and is redily available at any motorcycle shop.
