Killdmycobra Posted September 9, 2005 Report Share Posted September 9, 2005 If my bike is not warmed up all the way, it seems to bog when any throttle is applied. It will still do this even after a few minutes of idling. Anyone else have this problem? Quote Link to comment Share on other sites More sharing options...
eehsnab2 Posted September 9, 2005 Report Share Posted September 9, 2005 Sounds rich..... Quote Link to comment Share on other sites More sharing options...
batoutofshell Posted September 9, 2005 Report Share Posted September 9, 2005 mine starting doing the same thing at wot I went from a 290 to a 280 with fmfs and open box and it stopped. Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted September 9, 2005 Author Report Share Posted September 9, 2005 mine starting doing the same thing at wot I went from a 290 to a 280 with fmfs and open box and it stopped. 413362[/snapback] It did the same thing when the bike was stock. I dont think the mains would have anything to do with it. Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted September 10, 2005 Report Share Posted September 10, 2005 This may sound stupid, but hear me out. The first thing that would come to my mind is if you still have the TORS installed, is the parking brake accidentally set. If so the TORS will not allow the engine to rev above, I believe, 2000 RPM or right around there. The second thing I would say if that is not the case is that it is probably just not warm yet. Even though it may be sitting idling, if you are not applying any throttle variation the bike is still going to want to bog right at first hit of the throttle. I have my jetting, and more importantly pilot and needle settings dialed in, and if I just let my bike idle for a minute, or two it will bog if you try to get into the throttle more than a little. Although, mine will usually clean out after two or less partial hits of the throttle. Quote Link to comment Share on other sites More sharing options...
2strokesmoke Posted September 10, 2005 Report Share Posted September 10, 2005 my buds shee is pretty cold blooded it takes about 10 mins of running rough then cleans up good Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted September 10, 2005 Report Share Posted September 10, 2005 Mine does the same thing, and it will not idle when it is cold. I just give mine a little gas for 1-2 mins. then it will sit and idle. Some banshees are just cold blooded. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 11, 2005 Report Share Posted September 11, 2005 Once started...good idea to blip the throttle a few times, for the first minute or so. Notice I said BLIP... It helps circulate the water when cold, and helps it warm up quicker, too. (That's why the factory guys at your race blip theirs on the gate, to get that water ciruclating...) I normally 1/2 choke mine to start it...blip for about 10 seconds, close the choke...blip off and on for another minute, and shee idles just fine. Quote Link to comment Share on other sites More sharing options...
odaen Posted September 11, 2005 Report Share Posted September 11, 2005 if it only does it when your bike is cold, then, is it really an issue? Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted September 12, 2005 Author Report Share Posted September 12, 2005 if it only does it when your bike is cold, then, is it really an issue? 413750[/snapback] It will actually do the same after riding. I am going to richen up the pilots and see if it helps. I leaned them out and it made the problem worse. If this doesn work, i will go to the fourth clip on the needle. I am running the stock needle position with rad valves, rocket pipes, K&N pro design intake, and NOSS head. I have a 310 main and 27.5 pilots. I do have the TORS still installed which will soon be deleted. Quote Link to comment Share on other sites More sharing options...
