locogato11283 Posted September 13, 2005 Report Share Posted September 13, 2005 ill tell you guys would would be a really good test is to take a dune ported 350 and a identical 4mill with average dune port timing of 198ex and a 130 transfer with the usual add ons goodies,like vforce 2's ,k&n intake ,33 or 35 pwk carbs ,20cc domes,then get yourself a set of rockets ,cpi ,and shearer inframes and make several runs on a modern winpep dynojet with low humidity and same dyno setup entirely. i and a million others would like to see those results 414235[/snapback] i concur... Quote Link to comment Share on other sites More sharing options...
ROCKETMAN29 Posted September 13, 2005 Report Share Posted September 13, 2005 i concur... 414312[/snapback] but rockets were designed for 200 over 134! why f with the designers intentions? in fact how many rocket riders have these porting specs? i do! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 13, 2005 Report Share Posted September 13, 2005 but rockets were designed for 200 over 134! why f with the designers intentions? in fact how many rocket riders have these porting specs? i do! 414433[/snapback] i dont think i do but my bike still hauls ass...ive got whatever cleaned up cubs are... Quote Link to comment Share on other sites More sharing options...
rocketboy Posted September 13, 2005 Report Share Posted September 13, 2005 i think if you asked enough banshee builders youd find those are fairly close to an average dune port alot of people would run with shearers cpi or rockets,and while the 200 and 134 specs are said to be the ideal for rocket pipes ,it also should be mentioned the rocket pipes were designed around the perameters of 7millimeter ported stroker engine too,which of coarse would allow for your bike to run higher durations due to the increased torque and powerband width , 200 and 134 specs seems to me to be a very high port timing for a 350 with rockets ,for anybody that wants any lowend or torque anyways. Quote Link to comment Share on other sites More sharing options...
