snowfoxsx Posted September 7, 2005 Report Share Posted September 7, 2005 i need to get the rivits that hold on the gear to the clutch basket. does anyone know where to get them or just from the dealer, also how hard is it to reinstall the gear? i am putting a good gear onto a good basket because my basket is broke and the donor has a broken gear,or is there someone with a basket they are not using and want to get rid of it, let me know thanks Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted September 7, 2005 Report Share Posted September 7, 2005 Most people opt for the aftermarket billet basket and it comes with allen head bolts! Pm me if you need more info.. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 7, 2005 Report Share Posted September 7, 2005 call jeff @ fast racing 1-785-364-5325...he sells an aftermarket basket that will bolt on instead of rivet. its a good basket for a lot cheaper than most. call him up... Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted September 7, 2005 Report Share Posted September 7, 2005 Yeah , what he said about me!! Quote Link to comment Share on other sites More sharing options...
snowfoxsx Posted September 7, 2005 Author Report Share Posted September 7, 2005 Most people opt for the aftermarket billet basket and it comes with allen head bolts! Pm me if you need more info.. 412314[/snapback] ok, lets see a price on this stuff, anyone else have any ideas or stuff? thanks Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted September 7, 2005 Report Share Posted September 7, 2005 call jeff @ fast racing 1-785-364-5325...he sells an aftermarket basket that will bolt on instead of rivet. its a good basket for a lot cheaper than most. call him up... 412315[/snapback] .......... Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted September 7, 2005 Report Share Posted September 7, 2005 (edited) You can drill and tap the basket and run the screws from the back.The screws will need to have tapered heads,and you will have to countersink them a little bit into the back rataining plate.Not much clearance in the back,when the basket is installed so be carefull.Don't forget locktite and I also take a punch to the last thread on the screw to keep it from backing out.I have rebuilt a few baskets with no problems yet.I have also heard that you can buy the same size rivets at a John Deere dealership.I would say that it is better put it back with screws so you can easily change the cushions when they wear out. Mark Edited September 7, 2005 by MDS2106 Quote Link to comment Share on other sites More sharing options...
snowfoxsx Posted September 7, 2005 Author Report Share Posted September 7, 2005 You can drill and tap the basket and run the screws from the back.The screws will need to have tapered heads,and you will have to countersink them a little bit into the back rataining plate.Not much clearance in the back,when the basket is installed so be carefull.Don't forget locktite and I also take a punch to the last thread on the screw to keep it from backing out.I have rebuilt a few baskets with no problems yet.I have also heard that you can buy the same size rivets at a John Deere dealership.I would say that it is better put it back with screws so you can easily change the cushions when they wear out.Mark 412465[/snapback] what kind of screw do you mean? and how do you countersink them? could you send me some pics if you have? Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted September 7, 2005 Report Share Posted September 7, 2005 (edited) You can use an allen head or flat head screw,I used a tapered grinding bit to make the countersink holes in the back plate.The screws I used are 3/4" long.Once you drill the ribits out you will see how they were countersank into the clutch basket.You do the same type of countersink holes in the backplate.Don't let the thinness of the backplate fool you that metal is as tough as hell to drill or grind this will give you an idea http://www.accuratescrew.com/CatalogPage.aspx?ProdCat=113260 Mark Edited September 7, 2005 by MDS2106 Quote Link to comment Share on other sites More sharing options...
snowfoxsx Posted September 7, 2005 Author Report Share Posted September 7, 2005 thanks, i will give it a try! nothing to lose with the parts i got Quote Link to comment Share on other sites More sharing options...
89Steeda Posted September 8, 2005 Report Share Posted September 8, 2005 Nothing to lose? Be carefull, if it comes apart you'll lose the cases, basket ect...... I'd pony up for the billet basket. IMHO. Quote Link to comment Share on other sites More sharing options...
snowfoxsx Posted September 8, 2005 Author Report Share Posted September 8, 2005 ya, i guess your right! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 8, 2005 Report Share Posted September 8, 2005 i wouldnt risk tearin it all up because you dont wanna spend 150 or so for a basket..not worth it to me anyway... Quote Link to comment Share on other sites More sharing options...
