Polish Posted September 2, 2005 Report Share Posted September 2, 2005 I have a 400 stroker w/ 28pwk carbs.............will I get more HP out of the motor if I change to a 34mm carb??? Need help??? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted September 2, 2005 Report Share Posted September 2, 2005 Yes , and prolly torque too! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 2, 2005 Report Share Posted September 2, 2005 id go with 35mm pwk...im sure FASTOYS can get you some... Quote Link to comment Share on other sites More sharing options...
thegroup Posted September 2, 2005 Report Share Posted September 2, 2005 its mostly going to suck a hella lot more gas, go with a single carb kit. thats what my buddy did on his 03 after i put a 400 in it. stock carbs= 3hrs, gas tank BONE DRY single carb= 5hrs., just going on RES this is fact, and just my opinion on what u should do Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 2, 2005 Report Share Posted September 2, 2005 its mostly going to suck a hella lot more gas, go with a single carb kit. thats what my buddy did on his 03 after i put a 400 in it. stock carbs= 3hrs, gas tank BONE DRY single carb= 5hrs., just going on RES this is fact, and just my opinion on what u should do 410897[/snapback] i see your point about gas savings but who rides a 400 stroker motor for 3 hours straight?? most people drag motors like that and even if you dont 3 hours is a long ass timetoride with no fillup or no breaks...dual carbs will perform the best... Quote Link to comment Share on other sites More sharing options...
kw04 Posted September 2, 2005 Report Share Posted September 2, 2005 its mostly going to suck a hella lot more gas, go with a single carb kit. thats what my buddy did on his 03 after i put a 400 in it. stock carbs= 3hrs, gas tank BONE DRY single carb= 5hrs., just going on RES this is fact, and just my opinion on what u should do 410897[/snapback] i have a 4mm stroker w/ 34mm carbs on my 04 and i trail ride. but i dont think i have ever gone more than 45min with stopping to bs. and usually by the time i want to go home i have only used a tank maybe a tank and a half. just my .02 Quote Link to comment Share on other sites More sharing options...
