About how much for porting and assembly
I decided to go ahead and build a stroker instead of keeping the motor stock. I am goign to be running rocket pipes with this setup. It will be a stock cylinder with 4mm long rod stroker crank. About how much will it cost for a good port job and assembly of the new crank and pistons??? I have a guy down here, but i would rather have someone with experience with stroker and rocket pipe banshees.
Jeff
BTW, what are the best internals for my motor?
a h129 banshee stroker crank can be purchased for 429$ off the net fro m several places
porting is gonna run 400-500$ then theres stil lalot more to buy my friend .for the 4 mill stroker idea on a banshee ,you might as wel l just sell the stock jugs and run a cub mono IMO with cut domes and a some 35pwks :bolt::cheers:
