FOXBANSHEE30 Posted August 31, 2005 Report Share Posted August 31, 2005 If i advance my timing with the Ricky Stator plate +4 degrees and get a Noss Head with 20cc domes can i still run 93 octane gas? Or will i have to go higher octane?? My mods are below.....Thanks for the help. MEADOWS. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted August 31, 2005 Report Share Posted August 31, 2005 What is your elevation? Im at around 1100 feet and that is the setup I used to run. Quote Link to comment Share on other sites More sharing options...
FOXBANSHEE30 Posted August 31, 2005 Author Report Share Posted August 31, 2005 I live in Middle TN so im not sure of my elevation. Sorry. MEADOWS. Quote Link to comment Share on other sites More sharing options...
BURKE_DADDY Posted August 31, 2005 Report Share Posted August 31, 2005 what city are you in? Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted August 31, 2005 Report Share Posted August 31, 2005 Pinging denotes low octane.. Do a compression test anything over 150 LBS needs to run higher than 93 octane. FYI: I'm at 600 feet and 20cc domes and I'm at 175LBS hope this helps Quote Link to comment Share on other sites More sharing options...
dlnoss Posted August 31, 2005 Report Share Posted August 31, 2005 I'd probably increase the octane a little to be on the safe side. Maybe 10% to 20% race or av gas mixed with premium pump gas. Quote Link to comment Share on other sites More sharing options...
