Rickey Stator Stumped?
BrianEb
check your compression. also check and see if you are getting spark. The gap on the flywheel to the generator should be .0010. did you try to push/pull start it?
410000[/snapback]
Thats what I was going to say make sure 2 things! make sure the pickup coil is properley gapped w/flywheel.
and make sure U R getting spark!!
Hope this helps
I have a Ricky in my bike. It has worked flawlessly. Have you checked to make sure the TORS is unplugged under the tank, adjacent from the ignition coil? If that is plugged in, than the bike may or may not start, but certainly won't run with any throttle. Did you hear and see it run at the dealer when they allegedly swapped in a factory stator? Dealers are shady sometimes when you bring them a bike with some aftermarket goodies on it. If Ricky says it is good, I would think it's good. I run my pickup gap at .020". Make sure the TORS is completely disconnected. you can't just unplug the parking brake. The brain module under the fuel tank has to be disconnected as well.
