BANJO Posted August 28, 2005 Report Share Posted August 28, 2005 just finished a new top end/ crank... new parts ect.. got it running.. changed my jets.. went out for an hr.. the shee ran hard and strong.. next day went out to do a plug chop.. then.. 1 side blew again... it hurts.. took 2 months to build back up.. now i gota take it apart 2 days after.. the god danm jettings fucked up once again.. the bike was running perfect.. but it just wouldnt idle.. how can you do a plug chop if the bikes going to blow up.. im having bad luck with my shee.. anyways.. hopfully the next time ill get the jetting right the first time... and it will last my more the 1 hr of driving.. peace devin Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted August 28, 2005 Report Share Posted August 28, 2005 What kind of mods do you have? Were you're ports chamfered correctly after boreing?What does the top of you're pistons look like? Quote Link to comment Share on other sites More sharing options...
BANJO Posted August 29, 2005 Author Report Share Posted August 29, 2005 noss head 21cc .20 over 35mm c.v.. no air box.. fattys.. the bore job was great.. kick over in 3 kicks first time startinng it.. then first kick after that.. ill pop the head tomorow.. peace devin Quote Link to comment Share on other sites More sharing options...
Holyman Posted August 29, 2005 Report Share Posted August 29, 2005 Sounds like an air leak to me. If you weren't running ultra lean already, then I doubt it's jetting. You've got an air leak on the blown jug. I would suspect jetting more if you were running dual carbs. Quote Link to comment Share on other sites More sharing options...
wayfst Posted August 29, 2005 Report Share Posted August 29, 2005 that cdi that i sent to holy would do that. rebuild it run for two hours, no problem, one hard run and rebulid time. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted August 29, 2005 Report Share Posted August 29, 2005 Sounds like an air leak to me. If you weren't running ultra lean already, then I doubt it's jetting. You've got an air leak on the blown jug. I would suspect jetting more if you were running dual carbs. 409266[/snapback] That's what I would say too. Did you do a leak down test? If not be sure and do one. Need to know how to do one, do a search and if no luck get back with us. Quote Link to comment Share on other sites More sharing options...
j28d Posted August 29, 2005 Report Share Posted August 29, 2005 Hey, it sounds kind of stupid, but did you examine the top of your intake boots where the crossover tube goes. Mine was cracked, but I couldn't tell until I pushed on the hole and then saw a hairline crack. Unfortunately, I had already burned a hole in the piston and scratched the crap out of the cylinder, which I had to go from stock bore to .50 over to fix. At least it was a excuse to get the jugs ported. Good luck finding your problem. Also, that was the same symptoms mine had, wouldn't stay running at idle, had to choke it when it was hot to get it to start. Quote Link to comment Share on other sites More sharing options...
j28d Posted August 29, 2005 Report Share Posted August 29, 2005 Sorry, I thought you still had 2 carbs. Are the rubbers good on the aluminum intake? I had hell getting mine to seal when I switched to a 2-1(got tired of jetting 2) and a even worse time getting the v-force 2s to seal up because of the hose in the way. If you can still start it now, spray some wd or carb cleaner around the intake to see if the engine note changes and remember what spot you were spraying to try and see what's leaking. Also, are your reeds still good? Quote Link to comment Share on other sites More sharing options...
BANJO Posted August 30, 2005 Author Report Share Posted August 30, 2005 im going to pop the head tomorow night.. i was thinking a air leak to but i checked all the bolts/ gaskets over at least 4 times.. anyways i hope its not to bad.. peace devin Quote Link to comment Share on other sites More sharing options...
DBLtapS Posted August 30, 2005 Report Share Posted August 30, 2005 I had the exact same thing happen to me. Your mods are the same too. I over-tourqed the head and and smooshed the o-ring on the coolhead. I havent rode mine much since the second rebuild but ti runs strong. I am taking her up north this weekend.... Quote Link to comment Share on other sites More sharing options...
