Killdmycobra Posted August 28, 2005 Report Share Posted August 28, 2005 I just got my rocket pipes in and i was wondering if 80+ hp is possible with 110 leaded. If so, please tell me your combo. There are some 70-90hp CPI shees around here that need to be dealt with accordiingly. I have the NOSS head with 19cc domes, timing plate, K&N trinity intake without lid, obviously the rocket pipes and boyesen reeds as of now. Everything else is stock. Where should i start?? Quote Link to comment Share on other sites More sharing options...
wayfst Posted August 28, 2005 Report Share Posted August 28, 2005 go easy on cpi bikes. you're going to need bigger carbs and a stroker crank to get in to the 80 hp range and be ridable, you can get the hp up there with out a crank but dude!?!? Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted August 28, 2005 Report Share Posted August 28, 2005 If all your doing with your banshee is drag racing, ditch the stock cylinders and get some cubs , but get ready to spend $3000 and more on setting up a 90+hp bike. Quote Link to comment Share on other sites More sharing options...
chris642 Posted August 28, 2005 Report Share Posted August 28, 2005 If all your doing with your banshee is drag racing, ditch the stock cylinders and get some cubs , but get ready to spend $3000 and more on setting up a 90+hp bike. 409201[/snapback] ya, definally go for cubs, throw a 4 mill crank and drag port and you should be around there. im hoping all your doing is drags, no way your getting 80+ HP in a bike you want to still be rideable in trails and woods. if you got the money, more power to ya!! Quote Link to comment Share on other sites More sharing options...
Dunsmoor86 Posted August 29, 2005 Report Share Posted August 29, 2005 I would say as of now you are putting out 40hp maybe little more, but not much. To get 80-90hp maybe a full drag port, stroker, with big alky carbs. And maybe than some. Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted August 29, 2005 Author Report Share Posted August 29, 2005 Thanks for the input guys. Yeah, i forgot to add that i plan on a 4 mil stroker crank and some porting. I would like to keep the stock jugs. Quote Link to comment Share on other sites More sharing options...
rocketboy Posted August 29, 2005 Report Share Posted August 29, 2005 you will not be in the same zip code as 70 hp bikes let alone 80+ hp machines with your setup ,id get a 4 or 7 mill cub if it were me expect huge financial loses and being on the brink of bancrupcy when its all said and done Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted August 29, 2005 Author Report Share Posted August 29, 2005 (edited) ya, definally go for cubs, throw a 4 mill crank and drag port and you should be around there. im hoping all your doing is drags, no way your getting 80+ HP in a bike you want to still be rideable in trails and woods. if you got the money, Edited August 29, 2005 by Killdmycobra Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 29, 2005 Report Share Posted August 29, 2005 go 4mm and youll hit 70 easy with proper porting and carbs... Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted August 29, 2005 Author Report Share Posted August 29, 2005 go 4mm and youll hit 70 easy with proper porting and carbs... 409264[/snapback] Awesome, which carbs and porter do you reccommend. I've seen some people running lectron carbs and they claim they are easy to tune Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 29, 2005 Report Share Posted August 29, 2005 Awesome, which carbs and porter do you reccommend. I've seen some people running lectron carbs and they claim they are easy to tune 409269[/snapback] there are lots of different builders out there. FAST, a & s, ssr, k and t and so on...depends on what you want exactly and how fast u want it back from them. as for carbs 35mm pwk are a really popular carb. they run very well with most 4mm setups. lectrons are nice but a bit pricy. i think the 35mm pwk will do the job just fine. Quote Link to comment Share on other sites More sharing options...
taldoc3 Posted August 30, 2005 Report Share Posted August 30, 2005 dig deep in the pockets for 80 hp Quote Link to comment Share on other sites More sharing options...
