yanks5164 Posted August 26, 2005 Report Share Posted August 26, 2005 im trying to get the most torque out of my banshee to make it better for motocross so which would give me the most torque and bottom end power a longrod crank setup or a stroker crank i am currently running dynoport 2into1 pipe proflow intake trinity 2into1 carb noss machine head w/19cc domes wiseco pistons speed freeks full port Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 26, 2005 Report Share Posted August 26, 2005 sounds to me like you already have a ton of low end power. long rod wont increae power, it will simply increase reliability. 4mm crank will give you more power but youll have to redo the porting in your cylinders to make it work right. i persononally highly recommend eric gorr's woods port. itrs got awesome low end and midrange power. i dont know about the porting you have but by "full port" i think of top end... Quote Link to comment Share on other sites More sharing options...
taldoc3 Posted August 26, 2005 Report Share Posted August 26, 2005 heavy flywheel=torque lightened flywhell= faster rev less bottom end Quote Link to comment Share on other sites More sharing options...
yanks5164 Posted August 27, 2005 Author Report Share Posted August 27, 2005 i thought a lighter flywheel would give more bottom end b/c is rotates faster basically which would b best for motocross Quote Link to comment Share on other sites More sharing options...
taldoc3 Posted August 27, 2005 Report Share Posted August 27, 2005 look in sept. 05' issue of dirtwheels pg.223 and let it explain Quote Link to comment Share on other sites More sharing options...
Killdmycobra Posted August 29, 2005 Report Share Posted August 29, 2005 im trying to get the most torque out of my banshee to make it better for motocross so which would give me the most torque and bottom end power a longrod crank setup or a stroker crank i am currently running dynoport 2into1 pipe proflow intake trinity 2into1 carb noss machine head w/19cc domes wiseco pistons speed freeks full port 408486[/snapback] What about a timing plate?? Quote Link to comment Share on other sites More sharing options...
wayfst Posted August 29, 2005 Report Share Posted August 29, 2005 dyna fs, I got mine from trinty. set it on number 3 and go. Quote Link to comment Share on other sites More sharing options...
2strokesmoke Posted August 29, 2005 Report Share Posted August 29, 2005 how about gearing Quote Link to comment Share on other sites More sharing options...
willow2679 Posted August 29, 2005 Report Share Posted August 29, 2005 The lighter flywheel gives more throttle response only the bad on it is that if you remove to much it stall easier than the heavier (the heavier one has more inertia that way it dosn Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted August 29, 2005 Report Share Posted August 29, 2005 I'm going out on a limb here but I bet that dirtwheels wasn't discussing the flywheel effect on a twin cylinder 2 stroke was it? Maybe more like a single cylinder thumper. A single thumper has a power stroke every 2 revolutions of the crank where as a banshee has 2 power stokes per revolution. The thumper uses the flywheel to aid in that revolution where there is no power stroke. What's the flywheel for on a banshee? Lights & ignition. Quote Link to comment Share on other sites More sharing options...
23champ Posted August 30, 2005 Report Share Posted August 30, 2005 I'm going out on a limb here but I bet that dirtwheels wasn't discussing the flywheel effect on a twin cylinder 2 stroke was it? Maybe more like a single cylinder thumper. A single thumper has a power stroke every 2 revolutions of the crank where as a banshee has 2 power stokes per revolution. The thumper uses the flywheel to aid in that revolution where there is no power stroke. What's the flywheel for on a banshee? Lights & ignition. 409411[/snapback] The same concept applys on two strokes as well. Quote Link to comment Share on other sites More sharing options...
reded Posted August 30, 2005 Report Share Posted August 30, 2005 I'm thinkin a heavier flywheel would help in motocross as it would have less tendency to stall in sharp corners and improve traction coming out of corners (less tendency to light the tires up). If your hookin up your makin time on someone who isn't. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted August 30, 2005 Report Share Posted August 30, 2005 The same concept applys on two strokes as well. 409776[/snapback] Ride a bike set up for MX with and without a lightened flywheel, then tell me which is better. I would never go back to a stock flywheel, mine never stalls and I got power on the throttle when ever I push it. It's a whole different ballgame on the twin, if it were a single weight would be better. One of the best investments I've made on my bike right up there with the single carb and Gorr port. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 30, 2005 Report Share Posted August 30, 2005 I'm thinkin a heavier flywheel would help in motocross as it would have less tendency to stall in sharp corners and improve traction coming out of corners (less tendency to light the tires up). If your hookin up your makin time on someone who isn't. 409781[/snapback] i put a heavier flywheel in the cr500 motor and only thing i noticed was that it had a little more on bottom. i think they are supposed to smooth out the power more, which it did to mine...i took it off tho once i had it stroked... Quote Link to comment Share on other sites More sharing options...
23champ Posted August 30, 2005 Report Share Posted August 30, 2005 Ride a bike set up for MX with and without a lightened flywheel, then tell me which is better. I would never go back to a stock flywheel, mine never stalls and I got power on the throttle when ever I push it. It's a whole different ballgame on the twin, if it were a single weight would be better. One of the best investments I've made on my bike right up there with the single carb and Gorr port. 409790[/snapback] Good for you, I envy your wisdom, experience, and knowledge. I think I'll go out and remove as much weight as I can off my trail motor, while I'm at it I' ll throw some CPI outa frame drag pipes on it. Power when you push the throttle...Good concept. Quote Link to comment Share on other sites More sharing options...
