another ?
wooten
i have read on here that some use gear oil while others use motor oil what is the difference in the two
407831[/snapback]
Gears oils are heavier or thicker than motor oils because this allows for better dispersion inside a gear box where there is not a pump to circulate the oil like inside a motor.
As for type, use a sythetic whatever you use and generally stay away from car oils 10w30 and lower, most of them have energy conserving additives such as moly. This can be identified by checking the API label where it will list "energy conserving". Whether you use standard motor oil or gear oil is up to you. There is benefits both ways.
what brand are you using
407933[/snapback]
I personally use Mobil1 15w50 cause it is readily available and doesn't contain the energy conserving additives. Also it's one of the best synthetics on the market. Others I would recommend are motul, redline or amsoil.
OK I wasn't going to answer this question, but it is always interesting to see the reaction.
I use F type ATF. I have used it for three years and not had any problems. I change the oil about every 20 hours. Its cheap and makes the clutch grip not slip!!
