momo20 Posted August 17, 2005 Report Share Posted August 17, 2005 i just rebuilt my whole engine...well i still have stock carbs , but i did the porting on the cylinders, still have the stock reeds, i do have a cool head and tommey t-5 pipes,and some dlnoss STROKER 21cc domes i also live in pueblo colorado where our elevation is like 4800 feeti think...its close to that....i just dont know what to jet my shee at Quote Link to comment Share on other sites More sharing options...
broke Posted August 17, 2005 Report Share Posted August 17, 2005 You have stroker domes, do ya? You might have to go into a little detail. Does Dave advertise those? Did you go with a stroker crank? I may be misundestanding something or I'm just an idiot. Quote Link to comment Share on other sites More sharing options...
momo20 Posted August 17, 2005 Author Report Share Posted August 17, 2005 you have to ask for em...the make it to where you dont have to use a head gasket....pretty nifty if i dont say my slef....and top quality...and yes i have the stoker crank with stoker pistons Quote Link to comment Share on other sites More sharing options...
thegroup Posted August 17, 2005 Report Share Posted August 17, 2005 all that sounds like is a cold head with inter-changable domes Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 19, 2005 Report Share Posted August 19, 2005 no what i think he ment to say was you don't have to use a BASE PLATE. the domes are cut(making more room for the piston on its 4mm longer stroke) so you can somewhat "hide" your stroker crank. Quote Link to comment Share on other sites More sharing options...
thegroup Posted August 19, 2005 Report Share Posted August 19, 2005 (edited) no what i think he ment to say was you don't have to use a BASE PLATE. the domes are cut(making more room for the piston on its 4mm longer stroke) so you can somewhat "hide" your stroker crank. 406142[/snapback] hum, i know when i put the stroker crank in my buddy's 03, we didnt need it. the 'shee look like a 350 with a Pro Design cool head, a Trinty 34 or 35 single carb and T6s, not a 400 with wisecos (got the kit from alba) Edited August 19, 2005 by thegroup Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 19, 2005 Report Share Posted August 19, 2005 hum, i know when i put the stroker crank in my buddy's 03, we didnt need it. the 'shee look like a 350 with a Pro Design cool head, a Trinty 34 or 35 single carb and T6s, not a 400 with wisecos (got the kit from alba) 406153[/snapback] so you are saying you didn't use the spacer plate or get the head modded for the extra stroke? did you use the stroker pistons? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted August 19, 2005 Report Share Posted August 19, 2005 I don't advertise the stroker domes but I should add them to the web site. They tend to be 'custom' so I don't keep many on the shelf. I also make 68mm domes, Blaster piston domes, a variety of Cub domes, and 'spec' domes where a builder gives me the specs they want. Quote Link to comment Share on other sites More sharing options...
thegroup Posted August 19, 2005 Report Share Posted August 19, 2005 http://alba.buyol.com/Item/BAN%2D400%2DSTROKER.htm here's the kit if u want to look. only thing was that i had to call in a special order on the pistons b/c the comes with stock bore and we need the next bore size up and this kit, OMG! just like the kit says, "It will feel like you're riding a whole new quad!" spend all six gear in a ten ft. line on lightly wet grass Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 19, 2005 Report Share Posted August 19, 2005 http://alba.buyol.com/Item/BAN%2D400%2DSTROKER.htm here's the kit if u want to look. only thing was that i had to call in a special order on the pistons b/c the comes with stock bore and we need the next bore size up and this kit, OMG! just like the kit says, "It will feel like you're riding a whole new quad!" spend all six gear in a ten ft. line on lightly wet grass 406160[/snapback] ok i see i bet the domes are already set up for a stroker crank so you are right you didn't have to use the plate. Quote Link to comment Share on other sites More sharing options...
thegroup Posted August 19, 2005 Report Share Posted August 19, 2005 ok i see i bet the domes are already set up for a stroker crank so you are right you didn't have to use the plate. 406381[/snapback] YES!, point for ME! Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 20, 2005 Report Share Posted August 20, 2005 yeh yeh yeh whatever just kiddin ya man. Quote Link to comment Share on other sites More sharing options...
