BansheeBoy17 Posted August 14, 2005 Report Share Posted August 14, 2005 Alright... I know I posted this before but I have more problems now that might be able to point out the exact problem, which i think it is - the clutch. It rarely , sometimes shifts when Im drag racing or going fast. I had it in nuetral and it just popped into gear today in the driveway. And when it gets hot I cant shift when the quad is stopped, the gears have to be moving in order to shift. Is it the clutch? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 14, 2005 Report Share Posted August 14, 2005 (edited) Possibly... Does it fade in and out? It might be starting to go.... Get a shift star mod, it'll help with shifting, especially finding nuetral while running and stopped. Take the side off...remove, look at and measure the plates. While you're at it...look at the pressure plate and hub. Shouldn't be notched ...nice and smooth. When you get it apart, give Jeff a call @ FAST Racing. He sells a great streetbike kit clutch for the banshee that gets great reviews here...I love mine. He can walk you through what to look for. He also stocks the pressure plate and hub, which...once I have him port my motor I'm definately going to get as well... Jeff Wendorff FAST Racing 785-365-5325 Besides good pricing and good parts, he's a helluva nice guy to deal with and will talk your ear off trying to help you out and offer advice. When I get a few more coin...I'm going to get my motor done up by him. Jeff is making me pay for it...since he doesn't work for free and won't "Donate" a FAST motor to me... I've begged, groveled...pleaded...he won't budge... Just kiddin Jeff....can't wait to get a few more bills to send my stuff to you. Edited August 14, 2005 by dajogejr Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted August 14, 2005 Report Share Posted August 14, 2005 Doesn't sound like it. Sounds like a tranny problem. Could be the clutch, but it doesn't sound like it. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 14, 2005 Report Share Posted August 14, 2005 Yeah...I was kinda thinking the same thing. However...pulling the clutch apart and inspecting all items involved will not hurt...and could be part of the problem if not the only problem... Or...worn out parts could cause the tranny to go bad, too... Quote Link to comment Share on other sites More sharing options...
BansheeBoy17 Posted August 15, 2005 Author Report Share Posted August 15, 2005 Well if it was the transmissoin, then it would be bad even at cold temps right? Like if something goes bad, its bad all the time, it cant fix itself, thats what I dont get .. its fine until it starts getting hot after running for a while then it does these problems. Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted August 15, 2005 Report Share Posted August 15, 2005 Tolerances change. Things move. It's really hard to say without seeing the bike. EDiagnosis is gonna be a guess on this one. How old is the motor? It may be time to go through the bottom end and trans. Quote Link to comment Share on other sites More sharing options...
sycoracer911 Posted August 15, 2005 Report Share Posted August 15, 2005 i thought ti was the tranny too Quote Link to comment Share on other sites More sharing options...
BansheeBoy17 Posted August 15, 2005 Author Report Share Posted August 15, 2005 Its only an 02'. I race supercross and use my clutch alot, Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted August 15, 2005 Report Share Posted August 15, 2005 That would normally only cause it to slip. Shifting would be easier with a clutch that doesn't grab. I think you have a bent shift fork or bad shift star. Hopefully it's just a shift shaft. They are easy to replace. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 15, 2005 Report Share Posted August 15, 2005 That would normally only cause it to slip. Shifting would be easier with a clutch that doesn't grab. 405011[/snapback] A clutch that doesn't grab might make it easier to shift...however, a clutch that isn't disengaging properly wlll cause it to shift like shit. usually that means springs, pressure plate/hub and or worn out/sticking plates. Either way...time to dissasemble the clutch assembly and inspect...hopefully you get lucky. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 15, 2005 Report Share Posted August 15, 2005 sounds like its time for all new clutch parts. mine would do the same as yours. it was hard as hell to shift when it got hot. bought all new clutch shit and new clutch and bam, problem solved. shifts like butter now...call FAST and get set up... Quote Link to comment Share on other sites More sharing options...
