kw04 Posted August 13, 2005 Report Share Posted August 13, 2005 alright my buddies she has an oil leak. but why the hell does it smell like 2-stroke mix. the oil leak is coming from the oil drain plug. any info would be good. Quote Link to comment Share on other sites More sharing options...
VinceDizzy Posted August 14, 2005 Report Share Posted August 14, 2005 Well if its comming from the drain plug its got to be tranny fluid. Replace the copper washer and tighten. It "should" stop. The only way you could get engine oil into the tranny is if your cylinder base gaskets are leaking, also the tranny oil will have a different texture and look if you had a cylinder base gasket leak. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted August 14, 2005 Report Share Posted August 14, 2005 Hopefully your friend didn't put 2 stroke mix oil in the tranny. I can see how tranny oil gets in the case but never heard of mix oil in the tranny. Generally if you have a clutch side crank seal leaking it will suck tranny oil into the crank case and then you have all kinds of problems. Cylinder base gaskets have nothing to do with preventing transmission oil leaks. Quote Link to comment Share on other sites More sharing options...
VinceDizzy Posted August 14, 2005 Report Share Posted August 14, 2005 Aww shit my bad. Either I was thinkin about a 4 stroke or it was 2:00 AM Quote Link to comment Share on other sites More sharing options...
