Reserve Tank Problem
mudcool
If you ran out of gas while on on, the petcock intake tube is not there anymore. On the petcock there are two tubes, a short one for reserve, and a longer one for On. This allows you a small amount of fuel for reserve to get you home.
Mine has the tubes removed too, so if I am On, the fuel will flow till the tank is dry.
Just don't run it dry.
I wouldn't bother with it unless it's run down to reserve all the time.
I was going to leave mine as is until the petcock started leaking. :(
The fuel tank switch was on the ON(main tank) and the banshee stopped.
I switched to reserve and it wouldn't start.
Checked the fuel tank and it was empty...
What do you think is the problem?
Thanks.
404288[/snapback]
I'd like to amend my answer. After getting this shits this weekend I've had plenty of thinking time on the toilet.
I think you're rear tires might be the problem.
Switch them around and see if you mysteriously have more fuel in your tank.
i was thinkin the same thing put some gas in there  banghead
404310[/snapback]
Being that the tank was empty, you probably have a kinked fuel line somewhere. Maybe your CDI is junk. Saw your CDI in half and let us know whats inside. Its a possibility the little AA batteries inside it need to be changed.
404336[/snapback]
404797[/snapback]
you guys are down right silly.. :shootself:
there is only 1 feul selector position on the peacock valve, when it runs out turn to off position, unscrew the tank and turn it over, there is a black hose coming off the gas lid from the factory that's threre for the reserve just attach it to the carbs and your ready.. banghead
(he asked for it didn't he?) :rotflmao::rotflmao:
