midnite Posted August 10, 2005 Report Share Posted August 10, 2005 Does anyone use one of these? What are the benifits? Does it rob top end power? Should I throw it in the trash? Thanks. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 10, 2005 Report Share Posted August 10, 2005 Do a search on "reed spacer" and you'll get plenty of opinions. Quote Link to comment Share on other sites More sharing options...
Yaxy Posted August 11, 2005 Report Share Posted August 11, 2005 If you are running larger carbs the spacers will help the carbs clear the clutch arm. If you are using stock carbs or a size very similiar spacers make a good paper weight. Either way they are one big pain in the butt if you plan on running the airbox and I would not recommend them Chris Quote Link to comment Share on other sites More sharing options...
duecebanshees Posted August 11, 2005 Report Share Posted August 11, 2005 Putting the reed spacer between the reeds and the cylinder moves the powerband slightly toward more lowend. Putting the spacer between the intake manifold and the reeds moves it slightly toward the topend. They do make some differance. It just happens to be more noticeable on a single cylinders two stroke. They also allow you clearance for bigger carbs. Quote Link to comment Share on other sites More sharing options...
VinceDizzy Posted August 11, 2005 Report Share Posted August 11, 2005 Yah do a search. I only got mine to clear the clutch rod, and only that reason. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted August 11, 2005 Report Share Posted August 11, 2005 Yah do a search. I only got mine to clear the clutch rod, and only that reason. 403422[/snapback] SAME HERE. Quote Link to comment Share on other sites More sharing options...
pimpeinkc Posted August 11, 2005 Report Share Posted August 11, 2005 i use them to allow my rad valves to fit with my 2into1 intake Quote Link to comment Share on other sites More sharing options...
Banshee 79 Posted August 13, 2005 Report Share Posted August 13, 2005 Does anyone use one of these? What are the benifits? Does it rob top end power? Should I throw it in the trash? Thanks. 403145[/snapback] Quote Link to comment Share on other sites More sharing options...
