Hiem joints for Laeger A Arms
sg30721
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
MonkeyBoy is correct. Heims are meant to be pulled radially. However the way they are setup on a-arms the loads are placed axially. This means that you must look at the radial load capacity and figure that you will see a 85%-90% (depending on the quality of the piece) decrease in the axial capacity.
BTW: That info was taken from The Chassis SHop catalog and is for Aurora brand rod ends. ;)
Edited by gimmeabeer
no thats not it at all. its like he stated: You will find that these arms were deigned for Heims from the start and use a larger size than would be necessary with a ball joint. its not that they inferior. its that they are being loaded in a fashion that isnt there strongest point. so to compensate a bigger size is used.
The only place that they are safe is on the top arm. The load isn't as much on the top arm (why Yam could get away with alum upper arms on the YFZ). Also the load on the upper a arm is on a horizontal plane, rotating on the lower a arm connection with the spindle.
Different loads entirely.
I haven't studied everyone, but Roll will not use a heim on the bottom. Ball joint or uniball.
  • 1 month later...
  • 2 weeks later...
On which arms? The 250R and 400 EX was uniball, the Yamaha arms have all been Warrior balljoints. Leaves the LTZ/KFX.
Could also be a move to a better design. Roll has been around much longer than Fireball.
A patent doesn't mean you were the first, just the first to run to the government and fill out the paperwork.
yea still with balljoints.
I got some crazy super Heimes/Uniball on my custom creations A-arms, way stronger than fireball heimes from what I have been hearing. Probably much stronger than any ball joint also...
Then again they are basicaly some kind of modified Heim Joint to be use on A-arms. They are HUGE and very Beefy, and the joint body is much thiker than a typical heim that looks like it might pop out if worn down.
Good thing about balljoints is that they are sealed and keep crap out that would wear down a cheaper heim joint.
Edited by Justintoxicated
422542[/snapback]
Run to the government huh?
design a few things and watch every one copy your stuff and sell it for cheaper and all that time you spent testing/developing going down the tube for some one else to reep your benefits you will understand why companies patent their ideas.
FYI/ the R&D that went into designing those very $$$$$$$
Edited by sanddragon2004
