RNBRAD Posted August 9, 2005 Report Share Posted August 9, 2005 I use 3M spray 90 402601[/snapback] That's the best stuff bar none. It's the super trim adhesive 088090 but it may just say 90 now. Another product I think would work good though I havent tried is liquid nails. I can never get the damn stuff off my hands so it's bound to stick grips. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted August 9, 2005 Report Share Posted August 9, 2005 Check this one out----Hair Spray!!!---thats right hair spray. Get a can of cheap airisol hair spray, give em' a good squert, slip on your grips, wait a little bit. Then your good to go. But alway use safty wire. Quote Link to comment Share on other sites More sharing options...
Holyman Posted August 9, 2005 Report Share Posted August 9, 2005 Belt dressing. A quick spray and it's stuck. In fact the more they try to twist, the stickier the glue gets. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted August 9, 2005 Report Share Posted August 9, 2005 I used grip glue and it has worked fine one mine. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 9, 2005 Report Share Posted August 9, 2005 I just bought billet grips. Look good and have never rotated or slid off and they don't require grip glue or safety wire. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted August 9, 2005 Report Share Posted August 9, 2005 I use an air compressor, stick the nossle underneath the grip inflate it to put it on and let off. Been doing it for years, never had to spend a dime. 402688[/snapback] Thats what I use and it seems to work good, but you have to cut a little hole on each end for the air and have another person hold the other grip when you put the last one on. I dident and it flew off and hit my brother . Also you dont have to cut your grips to get them off, just shoot air in the hole on the and and pull the grip off. Quote Link to comment Share on other sites More sharing options...
2twin350s Posted August 9, 2005 Report Share Posted August 9, 2005 YUP 3M SPRAY TRIM ADHESIVE. LITTLE TRICK SAND YOUR BARS UNDER THE GRIPS WITH SOME 8O GRIT TO GIVE THE GLUE A PLACE TO STICK AND THEN SPRAY WITH BRAKE CLEANER AND LET DRY THEN USE 3M SPRAY TRIM ADHESIVE AND COAT THE BARS AND INSIDE OF GRIPS PUT ON AND ADJUST AND LET SIT OVER NITE. NEVER COME LOOSE ON ME THAT WAY. ALTHOUGH I LIKE THE BELT DRESSING IDEA. I WILL HAVE TO GIVE THAT ATRY. THAT IS SOME STICKY CRAP.BY THE WAY, HAVE YOU RIDDEN OVER A 4 STROKE LATELY? Quote Link to comment Share on other sites More sharing options...
BansheeBoy17 Posted August 9, 2005 Report Share Posted August 9, 2005 I wrapped duct tape arund the end of my bars to make it thicker, then hairspray on the inside of the grips then just let it dry and it worked great for me. As for the getting warm part??? I race and ride ALOT and they never get slippery or turn. Maybe thats just with electrical tape I dunno Quote Link to comment Share on other sites More sharing options...
sredish Posted August 9, 2005 Report Share Posted August 9, 2005 It's funny how everyone has their own ideas on what to do and most probably work. hairspray and spray paint didn't work for me. what's worked the best is 3M Weatherstrip Adhesive in the red tube. You can get it at any auto parts and this stuff sticks. I usually put one thin layer and let it sit for 30 seconds and the goop on one good layer over that and slam the grip on, just be sure to hurry, it doesn't wait around. Scott Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted August 9, 2005 Report Share Posted August 9, 2005 Bansheeboy17 your trick definetly works.There is absolutely 0% slip with the grips that you had on those bars you sold me. Quote Link to comment Share on other sites More sharing options...
BrockMoto Posted August 10, 2005 Report Share Posted August 10, 2005 want an easy cheap fix? get some carb cleaner out of your cabinet at home spray it in your grips and put them on the bars then spin them around a little and let it dry you won't be able to pull it off!!! Quote Link to comment Share on other sites More sharing options...
pimpeinkc Posted August 11, 2005 Report Share Posted August 11, 2005 i use grip glue, i just make sure the grip and the bar are clean and not dusty,,, i usually take some sand paper to the bar and ruff it up a little. seem to be working fine..... i like the paint idea.... the wire, not so much.... but if it works then it works... Quote Link to comment Share on other sites More sharing options...
aguita Posted August 11, 2005 Report Share Posted August 11, 2005 i use gasoline and it works for me..never slip off . Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted August 12, 2005 Report Share Posted August 12, 2005 weather strip adhesive or any silicone adhesive, I use this stuff called "GLOOZIT", and its insane, I accidentialy got some on my front tire and almost 2 years later it still won't come off. Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted August 12, 2005 Report Share Posted August 12, 2005 Electrical tape will slip as soon as it gets warm and the adhesive gets gummy and hot. Not at all what you want in a MX race. 402507[/snapback] ive had it on all summer and it has worked fine and my grip hasnt moved a bit Quote Link to comment Share on other sites More sharing options...
