DUAL REAR SHOCK SETUP?
sanddragon2004
  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
I've seen that done with Marvin Comps, except they were side by side. I thought about going that route on mine so I could have lower pressures in each shock since I'm going no link, but after talking with the guys at Marvin Shaw, they suggested going a single Comp with a coilover.
How much does each one of those shocks weigh that you have there?
why not run a bypass and a coil carrier? itd be a lil heavier, but the adjustability of those things is insane. i believe if i was going to all that trouble id call up King and get a triple tube on the way.
no matter how much i look at tube framed objects, the craftsmanship always amazes me.
nice work!
Roger truly is a genuis, He has over 80hrs in that chassis, it is all hand made. and all one off custom design. the side of this chassis removes to allow the engine to slide in and out.
He is truly a wizard fabricator.
FYI, he is also the one who designed the Studded heim joints. "patent pending"
I guess I'll be the one to ask... Why?
There's really no need, and it would just add weight.
402287[/snapback]
i dont really see the point but thats just me...
402350[/snapback]
Cause you can. If I had the money too do crazy shit like that I would.
well the idea is a variable rate, having too different rates. Not saying its the direction we are going, or that its the way to go, its just something different. It may not be for everyone. But until you try something out, you will never know if it is something that will fly.
Those of you that have seen it pound through the woops at sand mnt at 95+ mph know how well it works.
Again just a different approach to suspension being tinkered with.
