cheap ways to gain speed
ShamRok
Nitrogen have bigger molecules than regular air, making it harder for Nitrogen to leak out of places air would.  :D
402323[/snapback]
nitrogen doesn't expand and contract like regular air with heat and cold which means your tire psi will be consistant in all conditions and even if you are running it hard and heating up the tire. that is why they use it.....
402330[/snapback]
and its perfectly dry so no moisture in yur tire.
if u are Draggin, get urself an override trans or a pvl ignition and ull see big difference on ur bike for under 500, or if u want something cheaper get urself some bigger carbs, and ya like someone stated on top lighten ur bike by taking unessary parts, maybe even light ur frame up.
KASRacing
