dashee03 Posted August 5, 2005 Report Share Posted August 5, 2005 i heard about advancing your time with a degree key what does this mean, how does it work, and does it have any down sides or put your bike in more of a bind Quote Link to comment Share on other sites More sharing options...
racer Posted August 5, 2005 Report Share Posted August 5, 2005 advancing timing simulates having more compression by causing the ignition to fire earlier than normal. the only real downsides are the possible need for more octane in your fuel. depending on your static compression you may or may not experience predetonation when using advanced timing. Quote Link to comment Share on other sites More sharing options...
switchblade Posted August 5, 2005 Report Share Posted August 5, 2005 (edited) When you advance your timing it will give you more lowend. The same goes with retarding your timing it will give you more topend. Since banshees have tons to top already I have never heard of some one retarding the timing. +4 degrees is a good safe number for a banshee on gas. If you wanted to run methenal you could go as high as 11%. Edited August 5, 2005 by switchblade Quote Link to comment Share on other sites More sharing options...
racer Posted August 5, 2005 Report Share Posted August 5, 2005 +45 degrees is a good safe number for a banshee on gas. If you wanted to run methenal you could go as high as 11%. 401395[/snapback] true, but the largest part of that is already integrated into the CDI and other ignition components. Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted August 5, 2005 Report Share Posted August 5, 2005 Forget the key and get the timing plate. Quote Link to comment Share on other sites More sharing options...
