tOj Posted August 5, 2005 Report Share Posted August 5, 2005 Lookin for a bit more power to add over the winter, here's what I'm running so far. .020 Over Wiseco Pistons RDZ In-frame Drag pipes (Shearer replicas) Boyesen RAD Valves K&N Clamp ons' Stock Carbs running 320 Mains 15/41 Gearing Porting is probably in the works for this winter, suggest some, as of now I'm looking to get it from Eric Gorr, since he's local I could go drop my cylinders off not send them off into the world of UPS.. any other suggestions.. Also I'm a pretty big dude so I need all the power I can get Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted August 5, 2005 Report Share Posted August 5, 2005 You got a good set of pipes, porting would definitely be the way to go. Add some bigger carbs with it and you'll notice a huge difference. I also recommend getting your flywheel lightened (pm boonman) as well as advancing your timing. The flywheel and timing is something you could do before the porting for a quick and fairly inexpensive extra bit of power. The porting will make the biggest improvement overall though. Are you planning on strictly dragging it? Quote Link to comment Share on other sites More sharing options...
Big Blue Posted August 5, 2005 Report Share Posted August 5, 2005 If you get port work I suggest that you buy a cool head and bump the compression up. Quote Link to comment Share on other sites More sharing options...
