jay shafer Posted July 25, 2005 Report Share Posted July 25, 2005 I have a choice of getting a 4mm or a 4mm w/ 5mm long rod. The Shee is used for recreational play no duning as of yet. Mostly big fields and fire roads. I like good midrange and I want to know which one of those combos will be the best. The pistons used will be the Vitos Superstock pistons 64mm. Also with advanced timing, k &n pods, noss head 19cc or 20cc domes, v force, with stock carbs for now. thanks in advance Quote Link to comment Share on other sites More sharing options...
superchicken Posted July 25, 2005 Report Share Posted July 25, 2005 your gonna have to run 795 series pistons with either crank.or if vito's has the same for blasters. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 25, 2005 Report Share Posted July 25, 2005 i would go with the 4mm longrod(115 rods). that is generally the most common setup and most high performance atv shopswill carry the cut domes you need to run that setup. why you goin with vitos? are they a 795 series piston or one that u can put directly in a stock stroke banshee? if they arent the 795 you cant use them. Quote Link to comment Share on other sites More sharing options...
superchicken Posted July 26, 2005 Report Share Posted July 26, 2005 not unless he's meaning the super stock blaster pistons.i think they fit the long rods.i just bought the 795's to make sure it worked.ive heard mixed things about vito's pistons even though they may be made by wiseco.to me wiseco is a proven piston so you cant go wrong Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 26, 2005 Report Share Posted July 26, 2005 not unless he's meaning the super stock blaster pistons.i think they fit the long rods.i just bought the 795's to make sure it worked.ive heard mixed things about vito's pistons even though they may be made by wiseco.to me wiseco is a proven piston so you cant go wrong 397108[/snapback] i only run wiseco's Quote Link to comment Share on other sites More sharing options...
PassionRE Posted July 26, 2005 Report Share Posted July 26, 2005 The Vitos standard rod 4mm cranks are absolute JUNK! Go with the Wiseco crank....Jim Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted July 26, 2005 Report Share Posted July 26, 2005 If you do go with the Vitos 4mm standard rod it does use a stock piston.The 4mm stroker with the + 5mm rod takes a blaster piston or the wiseco 795 series. The blaster pistons are for the bigger bores = 2mm and up. From my experience buy the wiseco stroker,with cut domes for a cool head.Oh yea you dont need a big bore to get fast just a good port job. Quote Link to comment Share on other sites More sharing options...
wayfst Posted July 26, 2005 Report Share Posted July 26, 2005 If you do go with the Vitos 4mm standard rod it does use a stock piston.The 4mm stroker with the + 5mm rod takes a blaster piston or the wiseco 795 series. The blaster pistons are for the bigger bores = 2mm and up. From my experience buy the wiseco stroker,with cut domes for a cool head.Oh yea you dont need a big bore to get fast just a good port job. 397133[/snapback] ditto: alot of the guys i ride with have stock cranks and keep up with our 7mm strokers. stroker cranks just gave us ridabilty on the low end in the sand ( i don't have to shift as much ). so if your looking for fast on flat ground spend your money on porting, reeds, stuff like that, leave the big motors to the steep and the deep! Quote Link to comment Share on other sites More sharing options...
jay shafer Posted July 26, 2005 Author Report Share Posted July 26, 2005 thanks for replies fellows. I will just get it ported along with my other goodies and go with cheetah cubs later on and then maybe a 4mm Quote Link to comment Share on other sites More sharing options...
bkabina Posted July 27, 2005 Report Share Posted July 27, 2005 Do not use the Vito's crank!!I know first hand they are junk! Quote Link to comment Share on other sites More sharing options...
racer Posted July 27, 2005 Report Share Posted July 27, 2005 The Vitos standard rod 4mm cranks are absolute JUNK! Go with the Wiseco crank....Jim 397128[/snapback] Do not use the Vito's crank!!I know first hand they are junk! use only wiseco for your reciprocating parts. unless you want a twister billet or something.......... Quote Link to comment Share on other sites More sharing options...
