BlueBanshe03 Posted July 23, 2005 Report Posted July 23, 2005 I was recently running Silkolene's Pro 2 SX oil, and i just bought the comp 2 pre mix from silkolene. on the back of my old oil it said that it was 100% synthetic and the new one says "synthetic ester based 2-stroke engine oil". I was wondering if i need to do anything special because of the change. sorry it might be a dumb question but i very recently just bought my shee and didnt know if it would do anything to my engine because of the change. Thanks for the help Quote
05bansh Posted July 23, 2005 Report Posted July 23, 2005 You shouldnt have to change anything. Just make sure you are jetted properly according to your mods and elevation. Quote
BlueBanshe03 Posted July 25, 2005 Author Report Posted July 25, 2005 But should i drain the old gas out of it so i dont mix them? Quote
RNBRAD Posted July 25, 2005 Report Posted July 25, 2005 But should i drain the old gas out of it so i dont mix them? 396738[/snapback] Might check the web site or read some fine print on the label. It will usually tell you if it's not compatible with other synthetics. Quote
