ish Posted July 19, 2005 Report Share Posted July 19, 2005 What kind would you all recommend. also if i go up .020 on the size do i have to open the head it is a cool head with domes. i know i need new domes. Quote Link to comment Share on other sites More sharing options...
switchblade Posted July 19, 2005 Report Share Posted July 19, 2005 wiseco and you won't have to change you dome at all. If they are damaged just buy the same size ones. Quote Link to comment Share on other sites More sharing options...
Dunsmoor86 Posted July 19, 2005 Report Share Posted July 19, 2005 Yes, Wiseco pistons. If you look around you are going to find much cheaper pistons but the thing is they are always cast pistons and not forged like Wiseco. Which cast is not as strong as forged or even close. Quote Link to comment Share on other sites More sharing options...
BansheeBrian Posted July 19, 2005 Report Share Posted July 19, 2005 warmup on the forged are crucial for longer life. Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted July 19, 2005 Report Share Posted July 19, 2005 wisecos or vitos power pistons (made by wiseco) they are a little lighter wich makes a big differance @ 8000rpm, make sure you hone enough clearence for the forged piston due to expansion. I also suggest go the minnimum so you have more rebuilds for the future, even if you went .080 over you wouldn't gain anything. Also remember .020 over dosn't make it a 370, and compression is always compensated by the manufactuer with the dome of the piston so nomatter what size you go it remains the same compression dictated by you cyl. head. Quote Link to comment Share on other sites More sharing options...
ish Posted July 20, 2005 Author Report Share Posted July 20, 2005 wisecos or vitos power pistons (made by wiseco) they are a little lighter wich makes a big differance @ 8000rpm, make sure you hone enough clearence for the forged piston due to expansion. I also suggest go the minnimum so you have more rebuilds for the future, even if you went .080 over you wouldn't gain anything. Also remember .020 over dosn't make it a 370, and compression is always compensated by the manufactuer with the dome of the piston so nomatter what size you go it remains the same compression dictated by you cyl. head. 394549[/snapback] thanks. well last night i finally figured out what size pistons i have in the thing. they are 66mm or .080 over. i was in shock cause the bike did not go that fast. so i beleive i only have 2 bores left till i have to re sleeve the cyl. correct? i found a set of wiesco .090 should i use that? i think it will be 66.25mm or should i just go to the max and make it 66.50mm? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted July 20, 2005 Report Share Posted July 20, 2005 i was in shock cause the bike did not go that fast394966[/snapback] Boring like that doesn't add much if any pwr. Have a machine shop look at it to decide how far to go on the cylinders. Quote Link to comment Share on other sites More sharing options...
Banshee 79 Posted July 21, 2005 Report Share Posted July 21, 2005 What kind would you all recommend. also if i go up .020 on the size do i have to open the head it is a cool head with domes. i know i need new domes. 394501[/snapback] Wiseco! Quote Link to comment Share on other sites More sharing options...
