I am currently running Yamalube 2R. And I was advised to run a synthetic oil, i thought about running klotz. If i do is this the best oil for it? and what ratio should i mix it at?
There is no best oil. Klotz does make a quality product that's for sure.
If you change the ratio you run now then you may need to rejet. I run 40:1 with maxima products. Should be fine for Klotz too.
Just run the gas out of the tank before adding the new fuel oil mixture and you should be fine.
buy klotz benol, i just bought a 2000 banshee, previous said theres over 100 hours on the bike and its entire life has had klotz benol ran through it, so that is what im currently using, its hard to find, i had to buy it on the internet, bout 40 dollars for a gallon of it, plus, it smells good.
I switched from 32:1 Yamalube to 40:1 Amsoil Interceptor with no problems at all. Seems to pull strong. Not a huge noticable difference though.
