2004LEBanshee Posted July 12, 2005 Report Share Posted July 12, 2005 It revs up ok when in neutral but when I get in gear hith the throttle it sputter real bad? Jetting is ok it decieded to do this in the middle of a day riding.? Quote Link to comment Share on other sites More sharing options...
superchicken Posted July 12, 2005 Report Share Posted July 12, 2005 maybe check your reeds,i know that they will cause your symptoms Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 13, 2005 Author Report Share Posted July 13, 2005 (edited) I pulled the reeds and there perfect looking. I also switched the stator with a working one and still the same. I noticed it sputters really bad at around 1/4 throttle but only when going in gear. There is no sputter at neutral. When in gear it will continue to sputter untill it gets full throttle and then sputters and accelerates to max RPM then when I shift it does it again. Come on guys I need this fixed by mon for a riding trip. Edited July 13, 2005 by 2004LEBanshee Quote Link to comment Share on other sites More sharing options...
CombatTalon2 Posted July 13, 2005 Report Share Posted July 13, 2005 I pulled the reeds and there perfect looking. I also switched the stator with a working one and still the same. I noticed it sputters really bad at around 1/4 throttle but only when going in gear. There is no sputter at neutral. When in gear it will continue to sputter untill it gets full throttle and then sputters and accelerates to max RPM then when I shift it does it again. Come on guys I need this fixed by mon for a riding trip. 392080[/snapback] Clean your carbs, sounds like what my banshee was doing. Found a clogged pilot. worth a shot. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 13, 2005 Author Report Share Posted July 13, 2005 They were recently cleaned but I give it a shot. Can a clogged piolot make a sputter at mid throttly?? Quote Link to comment Share on other sites More sharing options...
CombatTalon2 Posted July 13, 2005 Report Share Posted July 13, 2005 They were recently cleaned but I give it a shot. Can a clogged piolot make a sputter at mid throttly?? 392092[/snapback] thought you said 1/4 throttle.... my shee was doing the same thing. it would rev fine in neutral. Put her in gear and it bogged down really bad just off idle, give her some more gas it would clear up about 1/2 to 3/4 and ran awesome on top. give it a shot, if nothing else changed when you were riding i would look at the carbs first! Quote Link to comment Share on other sites More sharing options...
fixitrod Posted July 14, 2005 Report Share Posted July 14, 2005 If the weather got hotter you may just be to rich on the bottom. You could try turning your pilot screws out a little or dropping your needles one. ... if the temp got hotter than when it ran good. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 14, 2005 Author Report Share Posted July 14, 2005 Ok I dont think I did a good job of explaining this. If I put it in gear and let out the clutch even if I punch it (full trhottle it will still sputter while it climbs up in RPMS and clear up a little on top when reved out. If I stay at around 1/2 throttle it will just continue to sputter. Hope thats a little more clear. I appreciate the help. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 14, 2005 Author Report Share Posted July 14, 2005 If the weather got hotter you may just be to rich on the bottom. You could try turning your pilot screws out a little or dropping your needles one. ... if the temp got hotter than when it ran good. 392393[/snapback] I have ran it in warm weather with no problem. Also every day since then even cooler days it still does it. Quote Link to comment Share on other sites More sharing options...
MILO Posted July 14, 2005 Report Share Posted July 14, 2005 if jetting is right, carbs are clean, air filter's good and clean, and it just started you may want to double check your needle anyway. last weekend a guy i was riding with somehow lost the clip for the needle while riding his shee and he had all kinds of problems. Quote Link to comment Share on other sites More sharing options...
trex banshee Posted July 14, 2005 Report Share Posted July 14, 2005 doesn't the banshee bone stock have some kind of rev limiter activated if the parking brake as been used with out pushing it back off. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 15, 2005 Author Report Share Posted July 15, 2005 Havent had a E brake in 2 years. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted July 15, 2005 Author Report Share Posted July 15, 2005 Checked the needle and there fine, now what. I hate this shit. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted July 15, 2005 Report Share Posted July 15, 2005 Try leaning them just to see what happens. Your filter isn't dirty is it. Quote Link to comment Share on other sites More sharing options...
Brocster350 Posted July 15, 2005 Report Share Posted July 15, 2005 What ratio are you mixing your gas? Quote Link to comment Share on other sites More sharing options...
